OEM Wiring harness - Nissan Frontier Forum
post #1 of 8 (permalink) Old 08-14-2012, 09:25 AM Thread Starter
Quoted: 11 Post(s)
OEM Wiring harness
I have been looking for a wiring harness to plug into the back of my OEM radio so I don't have to cut my original harness. I do not have the RF system just the 6 speaker, 6 cd changer. I want to make my own harness to go to my OEM processor. I have seen many out there just not sure which one will fit. Any suggestions?
Murdered Out 2011 Pro 4X KC
Nismo Cold Air Intake
XTP Intake Spacer
2 inch lift
33 inch tires
Peragon Bed Cover
LED Conversion
Blue LED Grill and Body Lights
Brake Performance Cross Drilled and Slotted Rotors and Brake Pads
900 Watt MTX 6 Speaker System
Magna Flow True Duel Exhaust
http://www.clubfrontier.org/forums/s...pic40270_1.gif
dlrmav is offline
post #2 of 8 (permalink) Old 08-14-2012, 04:15 PM
Quoted: 7 Post(s)
Something like the
might work for ya, but assuming you are putting a Frontier OEM radio in a Frontier, you should be able to plug the radio right in.... shouldn't ya?
2012 Frontier, SL, CC, Short Bed, Tow Package, Leather
My Build Thread - Don't Be Jealous!
Dougie35 is offline
post #3 of 8 (permalink) Old 08-14-2012, 04:21 PM Thread Starter
Quoted: 11 Post(s)
Yes I am keeping my factory head unit. I am trying to run a harness down to my processor. Then to my amps.
XTP Intake Spacer
2 inch lift
33 inch tires
Peragon Bed Cover
LED Conversion
dlrmav is offline
post #4 of 8 (permalink) Old 08-14-2012, 04:28 PM
Quoted: 7 Post(s)
No clue, then.... Sorry....
Dougie35 is offline
post #5 of 8 (permalink) Old 08-14-2012, 06:32 PM
Mylt1's Avatar
Quoted: 2 Post(s)
for it to work correctly you will need an adapter harness and a reverse harness. you will have to hook up all the wires to each harness except for the speaker wires coming from the reverse harness.
05 LE CC 4X4. SUPER BLACK
Mylt1 is offline
post #6 of 8 (permalink) Old 08-17-2012, 05:29 AM Thread Starter
Quoted: 11 Post(s)
That is kinda what I thought. Thanks.
XTP Intake Spacer
2 inch lift
33 inch tires
Peragon Bed Cover
LED Conversion
dlrmav is offline
post #7 of 8 (permalink) Old 08-26-2012, 03:09 PM
Should be an easy Find.
You can get wiring harnesses at Walmart, just get like 1996 and up nissan harness . Not to say it will just be plug and play there will still be a little wiring to be done but your stock wiring harness will still be intact for if you ever want to revert back to stock. A harness at walmarts probably like 7 bucks if you are feeling extravagent you could order one off like crutchfeild for like 6 times that much.
SubChamp is offline
post #8 of 8 (permalink) Old 08-27-2012, 01:03 PM
Mylt1's Avatar
Quoted: 2 Post(s)
but you cant get the reverse harness at walmart and im not sure they have the correct harness for the newer nissans since the OP has a 2011.
Mylt1 is offline
  Nissan Frontier Forum > Mods and Technical Discussions > Audio / Video
