Old 07-03-2008, 08:09 PM
Wheelie's Avatar
IVA-205 Alpine
how can I get the auto dim to stay bright?.also how can I bypass the parking brake wire to view dvd'
wee
06 Frontier Nismo Kingcab 4x4
Old 07-04-2008, 11:17 AM
j_wilson315's Avatar
I don't remember which relay but it is manufactured by PAC. Already comes programmed for the IVA 205 parking brake bypass.
Old 07-04-2008, 11:39 AM
Wheelie's Avatar
what is PAC?
wee
Old 07-05-2008, 09:59 AM
Lsmith9523's Avatar
Its the PAC TR-7. Comes pre-programmed for the Alpines. The TR-7 is much better than the toggle switch set-up. With the PAC TR-7,,when you start your vehicle and the headunit powers up,,,everything is set (bypassed) and ready.
As for the auto-dim,,,,I think its under your "Display set up",,,your options for DIM feature is,,,,"on-off-auto",,,under "auto",,,you should have the right--left arrow options, allowing you to chose how bright or dim you want the auto set. I run my "auto-dim" around -2.
I hope this helps.
Old 07-06-2008, 09:54 AM
PAC TR-7 (pac-tr7) , Car Installation & Accessories, In-Dash Receiver Accessories & Installation - Sonic Electronix there's a link
Old 07-06-2008, 04:46 PM
Wheelie's Avatar
I hope this helps.
is it an easy install? just ordered one. Thanks
Old 07-07-2008, 08:24 AM
Lsmith9523's Avatar
Its pretty striaght forward...It will come with instructions on which wire connect's to what.
Old 07-10-2008, 08:10 PM
Wheelie's Avatar
well, its installed and im not getting video, I can hear it but nothing on the screen, I called pac but they are closed.
wee
I got the tr7 off of ebay, its defective, hooked the Alpine up with the brake wires and it works fine.
Old 07-14-2008, 05:44 PM
Lsmith9523's Avatar
Wheelie,,,honestly,,,when I received my PAC TR-7,,,,I had a hard time getting everything working also. The instructions are straight forward,,,but for some reason,,mine did the same as yours. I had to play with the wires,,,,to get the TR-7 programmed for the Alpine again. Also dont forget,,,when you have the pac installed,,make sure you flip the small switch to the off position. The small switch is only flipped to "on" during the program set-up. Once you get video,,,flip the switch back to the "off" position,,which keeps the TR-7 programmed. If you installed the Pac TR-7 with the switch flipped "on" it will try to program again,,,then you have to follow the instructions on how to program for Alpine again. Which is a series of touching wires, watching the small red LED blink,,to know how its programmed. I hope this is not more confusing..Good Luck
Old 07-15-2008, 09:16 PM
Wheelie's Avatar
it doesnt want to stay programmed.I turn the power off and it doesnt work when I turn the power back on.
wee
