This is a how-to on installing steering wheel audio controls in a truck that didn't come with them from the factory. It is only for using them with a PAC adapter and an aftermarket headunit. It's not for those that want to add the factory six disc. I never had that and I don't know anything about it. So far I've added these to my Frontier, my wifes Pathfinder and my sisters Xterra. My truck is a 2005 LE crew cab 4x4. They all use the same wires. Just make sure your aftermarket headunit has an
OE REMOTE input on the back.
Tools you'll need-
Phillips head screwdriver
T-15 torx screwdriver
Small flathead screwdriver
Medium sized flathead screwdriver
Wire cutters
crimper.
Parts you'll need-
The steering wheel controls PN 25550NA from courtesy parts- $69.02 shipped
A PAC adapter for your radio make. Mine were alpine & Pioneer about $45 ea
22 gauge crimp connectors.
Step 1: Disconnect battery and let it sit for 5 minutes.
Step 2: Remove old cruise control switch.
start on the bottom in the middle of the wheel there is a hole with a metal tab in there. Gently push it up with a screwdriver. This will release the airbag and it will pull out.
Step 3: Using T-15 torx driver unscrew blank cover on left side of wheel and remove.
Step 4: Using T-15 torx driver unscrew old cruise switch cover and remove.
Step 5: Disconnect connector in steering wheel. And your old stuff is out.
Step 6: Install new cruise switch and screw in.
Step 7: Install new audio control and screw in.
Step 8: Plug in new wiring connector and tuck the cable between the two behind the metal tab. You had to pull it out of there to get the old one out. It's just tucked in there to get it out of the way.
Step 9: Double check that you plugged everything in and screwed everything down and reinstall the airbag. I just held mine while I was doing this so I didn't have to disconnect it or have it hanging by it's cables. You just push on the airbag until it snaps in.
Step 10: Take your old cruise switch to the work bech and remove a small plastic tab from the side of the connector. This will let you pull the wires out. I had trouble the second time I did this and ended up just cutting the plastic. You want the three connector pins from inside it so try not to damage them. And you want enough wire on them to be able to connect a new wire.
Step 10: If you didn't already have it out. You have to remove the kickpanel and lower dash panel under the steering wheel to get the lower steering wheel column cover off.
Step 11: You have to remove 3 screws from the bottom of the column cover and then use the small screwdriver to gently pry them apart. Now you have access to the connector on the bottom of the steering wheel. It's the gray one not the yellow. The yellow is for the airbags.
Step 12: Now it's time to wire up the infamous PAC switch. In this case the PAC-SWCPS going to an AVIC-D3. You start out with your wiring harness. Pull the red wire, black wire and white wire off to the side and fold up and retie all the others as they wont be used. Get your 150 ohm and 47 ohm resistors ready.
Step 13: Next crimp the 47 and 150 ohm resistors onto the WHITE wire. Then put another butt connector on the end of each resistor.
Step 14: Remember those pins you took out of the grey connector from the old cruise control? You take the connector on the back of the steering wheel out and there is a small white tab on the side. Pop this out a little bit and insert your wires into the three empty slots on the top row left side. Here's a picture from my last thread about this. In the middle row of pics they're going to pins 1,2,3
The red wire I have going into pin 1 will be connected to the
47 ohm resistor and the green wire is going into pin 2 will be connected to the
150 ohm resistor. The black wire I have going into pin 3 will be connected to ground. And the hard part is done.
Step 15: Insert grey connector back into bottom of steering column and zip tie the wires you just put in to the existing harness.
Step 16: On the PAC adapter harness take the black wire and connect it to ground. Then connect the red wire to ACC 12v. I just tapped it into the stereo harness ACC 12v line. Which happens to be red also.
Step 16 plug PAC harness into PAC adapter. Then plug the remote wire (it looks like a headphone jack) into the OE remote input on your headunit and secure the adapter in somehow. I just stuck mine on the metal bracket.
Step 17: Program the version number. Our trucks are version 3. Follow the directions on how to set it.
Step 18: Program the buttons. There is a sequence chart in the PAC directions that you have to follow depending on which brand radio you have. Since I was installing a pioneer there is no option for power. So I just set the power button as mute.
Step 19: Put your dash back together and enjoy not having to lift your hands off of the wheel to perform basic functions. On a side note. decide before hand what functions you are going to program and which you're going to skip. When I first did this mod the preset up/down came before track up down and the adapter wont do both it just takes the first one input while programming. I prefer track up/down personally but it's up to you.
