Horn circuit - Horn changeover to Hella Supertone - Nissan Frontier Forum
post #1 of 10 (permalink) Old 03-05-2012, 09:09 PM Thread Starter
Sixspeed-SV's Avatar
Quoted: 48 Post(s)
Exclamation Horn circuit - Horn changeover to Hella Supertone
Greetings,
I am having trouble to locate the circuit of the horn to make a change over to the Hella "supertone" horn. I have located the nice dry relay box in the engine room and thread the wire from the horn fitment. The horns have mounted nicely to the frame behind the grill on the top rail cross member.
question: Is the Horn on the steering column a negative lead?
this is mentioned as an option for connection as either positive or negative poles .. what do you know about the circuit? thank you.
Threading the wire into the cabin looks like a challenge - a lot of investigating. Disturbing the factory set up is asking for problems when the task has been dumb. Your thoughts on the matter?
thank you.
Sixspeed-SV is offline
post #2 of 10 (permalink) Old 03-07-2012, 09:22 AM
Quoted: 5 Post(s)
Why not just remove the connector from the factory horn(s), tap into the green wire, and connect your new horn between the green wire (+) and ground (-). That gives you the option to restore the original horn in the future by just plugging the connector back in.
The horn switch in the steering wheel is low side switched (to ground, what you called "negative lead"), and operates a relay that switches fused battery positive to the horn. So the horn itself is high-side switched.
inov8 is offline
post #3 of 10 (permalink) Old 03-07-2012, 07:40 PM
Quoted: 2 Post(s)
bypass existing horn wiring and rewire into the cab? wow talk about needlessly creating more work than needed without any benefit.
and should you blow a fuse if the new horn draws too many amps, you can wire in a relay using the EXISTING stock horn wiring.
zoomzoom is offline
post #4 of 10 (permalink) Old 03-08-2012, 10:41 PM Thread Starter
Quoted: 48 Post(s)
Thank You!
The Hella horn requires more amps than the standard horn circuit. I will fry the original circuit. It seems like new lead wires routed to the relay box in the engine compartment... this is 2nd generation and the fuze box, relay, on-board CPU/block is on the right side. Heavy wire harness! There is little room to thread fresh lead wires into the steering column through the fire wall without a breach of the passenger cabin.
suggestions ideas?
post #5 of 10 (permalink) Old 03-09-2012, 09:36 AM
Quoted: 5 Post(s)
According to the Hella web site, these horns draw 5.5A each, 11A for both. The factory horn circuit is fused at 15A. Nothing will "fry", but I like to see more like a 2:1 margin between fused and expected current.
I'm with Zoomzoom on this one . . . just trigger off the factory horn. There is no benefit to running extra wires into the steering column or relay module, and lots of opportunities for disaster.
Here is the circuit I would use if installing the horns in my truck. You can leave the factory horn(s) connected for "mega-loud", or pull off the connector . . . . your choice.
The inline fuse and Bosch automotive relay are available from Radio Shack, Amazon, Parts Express, WalMart, etc., for less than $5. A relay may have even come with the horns.
inov8 is offline
The Following 4 Users Say Thank You to inov8 For This Useful Post:
Ahgalaga (06-26-2012), crewmaxxis (03-09-2012), dubie2003 (03-09-2012), Sixspeed-SV (03-11-2012)
post #6 of 10 (permalink) Old 03-09-2012, 12:45 PM
Quoted: 2 Post(s)
^^ exactly.
please trash this idea of wanting/needing to run a new wire through the firewall into the cabin then into the steering column or wherever else you're thinking. it's useless and unnecessary. inov8 has presented you with a simple diagram that is most effective for what you are trying to do.
zoomzoom is offline
The Following 2 Users Say Thank You to zoomzoom For This Useful Post:
post #7 of 10 (permalink) Old 03-11-2012, 09:48 PM Thread Starter
Quoted: 48 Post(s)
Hella Horn
Fantastic information. A 30amp relay was included with the Hella box. thank you all for the input.
post #8 of 10 (permalink) Old 06-26-2012, 08:51 PM
[quote[/quote]
Hi, I wanna do this install tomorrow. I had an air horn installed before so my factory connector was cut off. I understand running the green wire to #85 in the relay but what to i do with the black wire?
thanks
Ahgalaga is offline
post #9 of 10 (permalink) Old 06-26-2012, 10:02 PM
Quoted: 5 Post(s)
The black wire is connected to chassis ground through the factory wiring, so you have 2 options:
(1) As shown in the drawing, connect both relay terminal 86 and the negative horn terminals to chassis, and don't make any connection to the black wire at all.
(2) Connect relay terminal 86 and the horn negative terminals to the black wire instead of chassis ground. With this option, neither connection to chassis are required because the black wire supplies the ground connection.
inov8 is offline
post #10 of 10 (permalink) Old 06-26-2012, 10:09 PM
Perfect, thanks for your help and info
Ahgalaga is offline
  Nissan Frontier Forum > Mods and Technical Discussions > Audio / Video
