Old 09-06-2008, 01:27 AM
Pro2X's Avatar
having problems with speakers
Here is my rear setup just in case you dont feel like reading my sig
JL Audio 300/4 amp
Polk Audio Momo 6.5 comps and Polk Audio Momo 6.5 coaxial.
Problem - Rear speakers will not turn up with out the yellow/orange light comming on the amp (which I believe is the protect light b/c of clipping) My front comp set is nice and loud and have 0 problems...The rears are so low that when sitting in backseat - you here 0 words/tunes comming from them. If you try to turn up the rears (whether from HU or Amp) they start to clip and cause the amp to throw the yellow/orange light. Is the crossover just crappy? I know Im not putting much power to them because I hardely have the things turned up.
Solutions - I have rewired the driver directly to the amp and then have the tweeters still hooked to the crossover but its still doing the same thing. Im ready to take these out and buy the Polk Momo comps for the rear as well.
Any solutions or pointers?
1 day, Pro2x will be completed...
Performance: nismo cai, tbs, ims, ground kit, coolant bypass mod, optima yellow top, d. thorley headers, all 4 cats removed, magnaflow muffler, and new piping
Exterior: tinted windows, black billet grill, colormatched headlights, fiberglass bed cover
Interior: pathfinder switch mod, katskin 2 tone leather, KW-AVX706 dvd/cd, Sundown 1500d, JL 300.4, JL12w6v2, Polk Audio Momo 6.5 comp/6.5 coaxials
Suspension: cst 4" spindles,prg 3" spacers, Alcan 8 leaf pack, extended saw shocks, extended ss brake lines
Wheels/Tires: pro comp 7189's with nitto tg 295/75/16
Offroad: m226 swap, titan alum diff cover, mag hytec seal, ac diff skid
I will support Barack Obama as much as everyone supported George W. Bush!
Old 09-06-2008, 01:43 AM
minman's Avatar
I have the polk momo coaxials in the rear. No problems running through alpine amp to polk crossover (included with momo's) to speakers. Is there any way you reversed the woofer and tweeter wires coming out of the crossover that might have caused your highs to go to your woofer cone and your lows to go to your tweet?
Minman
'06 Frontier CC SE
Dynamat (doors, rear, floor, roof, hood, wheel wells), Dynaliner (floor only), Closed-cell Foam Insulation (doors and rear wall only), Pioneer BT HU, Polk db (dash tweets), Infinity Kappa (front doors) and Polk MOMO (rear doors) Speakers, Alpine Mono and 4-channel Amps, Boston Acoustics Sub in Custom Rear Console Enclosure, RF 3sixty Processor w/wired bass remote and aux. switch, Tonneau Cover, Westin BB, FX35 Bi-Xenon headlight mod, OEM Foglight Install w/PIAA H9 modified bulbs, PIAA Driving Lights, Optima Yellow Top, Nismo CAI, Nissan nuvi Docking Station w/ Garmin Nav., Hardwired Radar Visor Mount, 10" Roof-mount LCD, XM Receiver, 2nd Hidden Aux. Input.
Old 09-06-2008, 01:56 AM
Pro2X's Avatar
I dont believe so but I will check that out tomorrow...
update: I hooked up my front component set up to the rears and the light did not come on so that tells me its either a wiring problem or speaker/crossover problem...Will be taking apart tomorrow to find out.
Old 09-07-2008, 09:08 AM
WeeHooker's Avatar
I would suspect and eliminate the new wireing first. Run a few feet of temporary wire directly from the amp to the crossovers ( one side at a time to start.) If no improvement, then it's pretty much isolated to the Coax sets and they should be returned/ replaced.
p.s. Just to rule out an amp overload problem, it would be nice to get another set of speakers ( any/factory will do) and hook them up in the rear after the test below before buying new coaxials.
Old 09-07-2008, 09:18 AM
bigdog's Avatar
My guess is that you have metal contact. This happened to me when I first installed rear speakers. My 6" speakers were a little deeper then the ones I removed and while they did not appear to contact when installed, they would once they started bumping. Just pull the two rear speakers out of the door leaving them connected and test the stereo. If they work fine like that then your probelm is metal contact. What I did to solve it was wrap some electrical tape around the lip of the opening in the door and the problem was solved.
2006 SE CC 4x4 A/T:
