Old 05-12-2008, 10:37 AM
Amps are grounded to the same screw could this be an issue (they have seperate positve lines with different fuses)
Shorten your ground! Your ground wire should not run that long of a distance. It should only be about 2ft away max.
-Jason
06 SE KC 4x4 - Black
Old 05-12-2008, 10:38 AM
ToddG's Avatar
Originally Posted by Mylt1 View Post
not sure when they switched but almost every forum im on that has an audio section has had the same problem listed time and time again. which is why i will not use pioneer decks.
Or Pioneer anything for this guy. Just my opinion.
But anyway:
Definitely try grounding your HU DIRECTLY to the battery negative terminal (and only the terminal, no body ground).
If that doesn't fix it, ground your amps DIRECTLY to the negative battery terminal. Just throw wires in loose, rout them out the doors for a test. don't bother routing them all neat and incon****uous until you know if it that cures the problem. I had to do this on an Eagle Talon, it totally fixed the hum/whinning. Good luck bro.
(**** heh, picked up as a racial slur I suppose. i-n-c-o-n-s-p-i-c-u-o-u-s was the word.)
Interior Mods: Kenwood KDC-MP438U, Sirius, Polk Audio MMC6500 (front), Polk Audio DB651 (rear) Alpine PDX-5 @600 watts, Polk Audio DB104 sub w/custom fiberglass enclosure, Gentex Temp/Compass/Homelink Mirror, Weathertech floor liners front/mats rear, ScanGauge II w/blendmount.
Exterior Mods: Silverstar Ultras, Hella Micro DE driving lights, EZDown Tailgate Damper, Extang Full Tilt Tonneau cover, Weathertech side window deflectors.
Performance Mods: Flowmaster 50 Series dual in/dual out (PT# 524554)w/ stock dia. 2.25” pipe, Nismo CAI.
Write ups:
Old 05-12-2008, 12:46 PM
WeeHooker's Avatar
x2. A set of battery jumper cables should work for this test.
Mods: Access Lorado Tonneau, Raamat sound deadener, Custom Audio (JVC KW-GX700, XM, Ipod, Pioneer D702P, CDT HD-52, Infinity Ref, Alpine PDX4.100, Profile AP400 & PioneerTS-SW841D (front seat sub) Remote Start, Yakathule Racks, Wheel Locks, OEM All Season Mats, Silverstar Ultra Headlights, LED Back-ups, 13" Rubber Antenna, EZDown Gate Dampener, Light Buster hitch light.
Old 05-12-2008, 04:09 PM
demondrive's Avatar
you dont want your grounds to be longer than about 2ft like jaf06se said. please provide some pics of your grounds so we can see, or describe em better as well as guaging used
Old 05-14-2008, 08:44 PM
helotaxi's Avatar
Your ground goes all the way back to the neg post of the battery. Which would you rather have carryin the current most of the distance: copper wire of gauge sufficient to carry the current needed by the amp or sheetmetal of unknown thickness and conductive properties? I typically run my ground all the way back to the battery, good ground every time.
Artificial Intelligence is no match for Natural Stupidity.
Never underestimate the power of stupid people in large numbers.
