Old 05-19-2008, 09:37 PM
codyfrontier's Avatar
fianally installed new head
100_2122.jpgfinally installed new head. just a starter. also installed Polk II EX series components. have a question about a slight distortion on one component sub. i think its going out or does anyone have some suggestions. the install was fairly easy but the adapter is kindoff different then used to. and to all with 98's you will need an antenna adapter(pain in the a$$ if you didn't know u needed) THANKS TO ALL FOR THE HELP!! let me know your thoughts
Old 05-19-2008, 09:48 PM
Looks like ur missing a ashtray Is the bottom din tray stock? it looks small to me. Now you need to start thinking about some bass in the back. Over all looks nice.
Old 05-20-2008, 10:54 AM
ToddG's Avatar
Originally Posted by codyfrontier View Post
Attachment 17513finally installed new head. just a starter. also installed Polk II EX series components. have a question about a slight distortion on one component sub. i think its going out or does anyone have some suggestions. the install was fairly easy but the adapter is kindoff different then used to. and to all with 98's you will need an antenna adapter(pain in the a$$ if you didn't know u needed) THANKS TO ALL FOR THE HELP!! let me know your thoughts
Nice job on the install. If one of your woofers is distorted it could be a few things:
1) it's on it's last leg (are the speakers new or used?).
2) you have the polarity reversed somewhere (+ is on the - terminal and vice versa).
3) be sure that your door panel (or anything else) is not interfering with the cone (ie. pressing against it).
To trouble shoot, swap woofers from door to door. That will tell you if it's the woofer or inline somewhere on that side.
Just a few things of the top of my head, good luck bro.
2006 SE 4x4 CC, 6 speed, Sunroof, Red Alert / 2006 Altima SE-R, Super Black
Interior Mods: Kenwood KDC-MP438U, Sirius, Polk Audio MMC6500 (front), Polk Audio DB651 (rear) Alpine PDX-5 @600 watts, Polk Audio DB104 sub w/custom fiberglass enclosure, Gentex Temp/Compass/Homelink Mirror, Weathertech floor liners front/mats rear, ScanGauge II w/blendmount.
Exterior Mods: Silverstar Ultras, Hella Micro DE driving lights, EZDown Tailgate Damper, Extang Full Tilt Tonneau cover, Weathertech side window deflectors.
Performance Mods: Flowmaster 50 Series dual in/dual out (PT# 524554)w/ stock dia. 2.25” pipe, Nismo CAI.
Write ups:
Old 05-20-2008, 09:26 PM
thanks for the comments. ya its still stock on the bottom bin tray(still have ashtray) and the speakers are used and im only getting the distortion on one side. will check connections and speaker clearance. then the speaker swap. thanks again for the info. any ideas on a box that will fit so i can still use the side drop down seats?????
