Originally Posted by bobcats_qb
OK, so even though the RMS says 150, what would happen if i was to say... Run an amp that puts out like 600 watts max, matching the 600 max that I would have if i had two of these?
Would I get better quality from something like this, or should i stick with the 300 wat amp???
It depends on what amp we are talking. Most of the top brands don't list Max power ratings because it's not a good way to measure the power for music. SPL is different. It is always better to have too much power than not enough. You can always adjust the gain with a DMM.
Ex: you have 2 subs with a total RMS of 500 watts, your amp is rated at 1200 watts RMS. You would simply set the gain so the amp would push 500 watts @ 50Hz when the head unit's volume is at 75%.
