I have a 2009 nissan frontier se 4x4. Currently my stereo I installed 2 years ago just turned off and doesnt turn back on when I start the truck. If I disconnected the power from the stereo itself to the truck it turns back on but only for that time and after a while it just turns off again. I'm open for any ideas on how to fix the issue... thanks in advance
there's no other audio components involved, just the stereo. The stereo can be turned back on when I unplug the stereo from the main connector and back again but only for that first ignition and after it just stays off.
First step is gonna be checking out the wiring. Pull the HU out and see if you are getting 12v DC at the switched power wire at the back of the stereo with the ignition on. Check out the ground while you're in there too.
