worthless lojack - Nissan Frontier Forum
post #1 of 3 (permalink) Old 05-19-2017, 01:57 PM Thread Starter
worthless lojack
i recently bought a 2006 nissan frontier in puyallup washington and i live south of spokane. i was suppose to have two keys and they could only find one so they said they would make another key and send it to me. it came in the mail the other day but along with it was a key fob witch didn't work and no idea what it did and no notes either, come to find out through research on google it is a lojack with a dead battery and is not supported in whitman county totally worthless. could this have to do with the hard starting or is my camshaft position sensor bad like the scanner says? the dealer wants 97 bucks for the sensor plus over 100 bucks to scan it. so i went to autozone and bought my own scanner for 30 bucks and it told me about the bad sensor. by the way whitch side is bank 2 or should i replace both just to be safe.
nicetruck is online now
post #2 of 3 (permalink) Old 05-19-2017, 03:12 PM
Quoted: 48 Post(s)
key fobs usually need to be programmed together. The procedure is probably somewhere on this forum but I'm a newb still and haven't looked. If not it will be in the FSM or owners manual. Not sure what lojack would have to do with your key FOB or a cam position sensor. If your car is saying you have a problem with a cam position sensor I would test that first before thinking it anything else. If they are cheap enough I sway swap them both out. Like headlights, when one blows the other is surely to follow.
robj80 is offline
The Following User Says Thank You to robj80 For This Useful Post:
waxman (05-20-2017)
post #3 of 3 (permalink) Old 05-20-2017, 12:43 PM Thread Starter
i am planning to change the sensor soon. to bad the lojack is not supported in this area.
i am planning on replacing the sensor soon. it is to bad lojack is not supported here.
