*WARNING* - Clean your Battery Terminals - Page 3 - Nissan Frontier / Navara Forum
  #21 (permalink)
Old 11-01-2012, 09:13 AM
Mine came back too. That's when I used the baking soda in order to neutralize everything around the battery: battery itself, positive and negative cables, hold down bracket and the tray. I repainted the hold down bracket too since it had corrosion as well.
  #22 (permalink)
Old 12-13-2012, 05:55 PM
A can of Coke & some baking soda. Sprinkle it on there & wash it off 5 minutes later.
2012 Nissan Frontier KC SV Auto 4x4, Side Step Rails, Bull Bar, Bed Extender, Mud Gaurds.
  #23 (permalink)
Old 12-13-2012, 08:36 PM
NISMO_R6's Avatar
Send a message via AIM to NISMO_R6
That Coke stuff is pretty crazy.
Anyways, I ended up replacing my acid battery with a DieHard Platinum.
2003 Yamaha Blue YZF-R6
2006 Nismo Storm Gray Frontier KC 6sp 4x4 V6 (JBA SS Exhaust, Kumho Mohave A/T)
The Following User Says Thank You to NISMO_R6 For This Useful Post:
BCBrian (12-13-2012)
  #24 (permalink)
Old 01-08-2013, 07:30 PM
Is it safe to assume once the battery is replaced with, say an Optima, this won't happen?
  #25 (permalink)
Old 01-08-2013, 07:57 PM
Zedbra's Avatar
Feedback Score: 4 reviews
It can still happen, put the spray on the terminals to help prevent it
2007 Frontier LE Crew Cab LWB 4x4 w/leather
My Build Thread
The Following User Says Thank You to Zedbra For This Useful Post:
BCBrian (01-08-2013)
  #26 (permalink)
Old 01-08-2013, 08:05 PM
BCBrian's Avatar
Optima batteries do not have the vents that the stock battery has but corrosion can still form over time so the terminal spray is a good idea.
Check out the Sears DieHard Platinum battery. It is a gel style like the Optima but has more Cold Cranking Amps and a better warranty. It does cost a little more but if you are running lights and/or an aftermarket sound system it would be worth it.
2010 SE K/C V6 4X4 My Truck Build
Armor: Hefty 5 pc Skid Plate set. Shrockworks Sliders. Blue Torch Fabrication Differential Cover.
Suspension: PRG UCAs with 2.5" Radflos and 650 lb springs. Bilstein 5125s with Deaver AALs.
Wheels and Tires: Stock SE Alloys with Hankook Dynapro ATm LT265/75-16.
*FREE* Hollister Hills Tour Guide
*WARNING* - Clean your Battery Terminals!
Got Questions? Help us Help you
  #27 (permalink)
Old 01-08-2013, 10:44 PM
I already bought optima a couple weeks ago and cleaned the terminal.
  #28 (permalink)
Old 01-09-2013, 11:40 AM
JeniorNV's Avatar
This is the correct DieHard Platinum for our trucks: DieHard Platinum Battery : Best Car Battery Deals at Sears.
I cleaned my battery terminals in July and already had to do it again a few weeks ago. Next time they are due for a cleaning, I plan on dropping in a DieHard Platinum at the same time.
2009 SE King Cab 4x4 6 speed
My Truck
Suspension Lift Info 05+
BCBrian (01-10-2013)
  #29 (permalink)
Old 01-09-2013, 01:17 PM
NISMO_R6's Avatar
I ended up replacing my battery with that Die Hard Platinum. I was able to get it for $201 back in December. My old platinum battery was weak already anyways and the acid already ate out the metal rod harness previously.
