*WARNING* - Clean your Battery Terminals - Nissan Frontier / Navara Forum
Old 06-27-2012, 06:34 PM
BCBrian's Avatar
Corrosion on the positive battery terminal caused my ECU to fail. There is a service bulletin on this problem that says replacement of the ECU due to this issue will NOT be covered by the warranty. They claim it is a maintenance issue but it is not noted in the service and maintenance guide.
The stock battery has 2 breather vents which are located right under the terminals. The dealer knows to check these whenever your vehicle comes in for service. Since I do my own air filter and fluid changes, my truck had never been in for a standard service... only for a couple minor problems.
They had charged my battery at 10000 miles because it was slightly below normal and there was no corrosion at that time. I had also showed my service writer the battery last month because it looked damp on top and he said that it was normal. I got lucky and the service mgr agreed that with only 16000 miles that this should not have happened. Fortunately, the repair didnt cost me anything.
Clean your terminals and save your ECU and A LOT of $$$$$$. My dealer recommends doing this every other oil chg.
Here are pictures of the positive terminal before and after.
Just thought I would throw out a heads up and hopefully save some folks from a big repair bill.
2010 SE K/C V6 4X4 My Truck Build
Armor: Hefty 5 pc Skid Plate set. Shrockworks Sliders. Blue Torch Fabrication Differential Cover.
Suspension: PRG UCAs with 2.5" Radflos and 650 lb springs. Bilstein 5125s with Deaver AALs.
Wheels and Tires: Stock SE Alloys with Hankook Dynapro ATm LT265/75-16.
*FREE* Hollister Hills Tour Guide
*WARNING* - Clean your Battery Terminals!
Got Questions? Help us Help you
The Following 6 Users Say Thank You to BCBrian For This Useful Post:
FrontierNewport (10-29-2012), HighALT (12-13-2012), NISMO_R6 (11-01-2012), PnoY (03-23-2013), stealthtrep (10-31-2012), Volcano_God (06-27-2012)
Old 06-27-2012, 06:55 PM
frontyfan's Avatar
Good to know. Glad things worked out for you.
Sent from my Autoguide iPad app
My Build Thread
The Following 2 Users Say Thank You to frontyfan For This Useful Post:
BCBrian (06-27-2012), NISMO_R6 (10-29-2012)
Old 06-27-2012, 10:29 PM
FrontierNation3's Avatar
Good to know, thanks!
Is this what the dealership refers to when they say "do you want to have your battery terminals serviced?"?
2006 Nissan Frontier 4x4 CC [Build]
Radflo 2.0 Standard Travel coilovers, Radflo 2.0 Emulsion rear shocks, Alcan 1" Leaf Springs, ShrockWorks Front bumper, ShrockWorks rear bumper, ShrockWorks Skids, H1 5000K Retrofitted Projectors, PIAA Fog lights, Banks Monster Exhaust system, 20x8.5 MB Motoring Gunner 6 AM wheels, Cooper Zeon LTZ 275/60-20 tires, StopTech Power Slot cryo treated Rotors, Hawk LTS brake pads, Boyo front view, rear view, undercarriage cameras, 20% tint.
2013 BMW X1 xDrive35i
Completely stock...for now.
The Following User Says Thank You to FrontierNation3 For This Useful Post:
Old 06-27-2012, 11:31 PM
Volcano_God's Avatar
Good post. Since I take care of mine the same way, I've never had to replace a single terminal nor have I ever failed to start due to corrosion. It cost a couple of smackers for a can of anti-corrosive terminal spay paint and a terminal brush... Basically enough to tend to 3-4 cars and you will never have issues again.
Remove terminals and clean and remove all corrosion with a terminal brush. Clean the post as well and wipe down the terminal area till clean. Be sure to tape and cover areas around the terminals once you're ready to spray the terminal paint as it never hardens and is a bit messy.
Once you do this you will not have to touch your battery or terminal till you replace the battery. All you need do is clean and repeat.
2008 Honda Odyssey EX-L with DVD/NAV. (PAID OFF!!) MODS: OEM fog lights, OEM wood dash kit, hood deflector, moonroof defector, and other mods.
2005 Nissan Frontier Super Black Crewcab LE 4x4 W/Desert leather interior. (PAID OFF!!) MODS: Nismo CAI, Nismo oil cap, Nismo radiator cap, Chrome OEM door handles, OEM hood deflector, OEM bed cover, E & G Classic stainless steel grill, and a few other mods.
2005 Nissan Altima 3.5 SE-R Sheer Silver/ Black/Red interior... GONE! You will be missed! 04.01.08 triplets killed the Altima SE-R!
The Following User Says Thank You to Volcano_God For This Useful Post:
Old 10-29-2012, 12:27 PM
BCBrian's Avatar
Take a quick look at your positive battery terminal
I looked at a fellow CF members battery yesterday and found this same issue in the early stages of corrosion. The battery that comes with these trucks is not suitable for steep terrain, due to the breather vents.
As stated above... the dealer will NOT cover this repair citing 'lack of maintenance'. An ECU replacement is approx $3000 per my service writer.
Just wanted to bump this as a reminder and to save you folks some big $.
The Following User Says Thank You to BCBrian For This Useful Post:
05Fronty4x (10-29-2012)
Old 10-29-2012, 03:17 PM
Zedbra's Avatar
Feedback Score: 4 reviews
What did you spray on there?
2007 Frontier LE Crew Cab LWB 4x4 w/leather
My Build Thread
Old 10-29-2012, 03:34 PM
Location: Fort Riley, Kansas (But hail from the great state of Louisiana!!)
use water/coke and a brush. Sometimes you may need a grill brush, but the stuff usually comes off easy. Save yourself some money and use the good ole boy trick of putting a coat of vaseline over your terminal. It works for sure!
"When you do the common things in life in an uncommon manner, you command the attention of the world"
2008 NISMO Crew Cab
Leveling Spacer, Plasti-Dipped Rims, Blacked out tint all around, Flowmaster 40, AFE Intake & Throttle Body Spacer 265/75/16 Cooper Discoverer STT's
Old 10-29-2012, 04:10 PM
NISMO_R6's Avatar
Send a message via AIM to NISMO_R6
Thanks for sharing this and giving a heads up.
I haven't been driving my truck much (600 +/-) in the last 8 months and I did an oil change a few weeks back and noticed the corrosion on the positive terminal. Now my urgency went up to top priority to getting that cleaned up tonight!
2003 Yamaha Blue YZF-R6
2006 Nismo Storm Gray Frontier KC 6sp 4x4 V6 (JBA SS Exhaust, Kumho Mohave A/T)
The Following User Says Thank You to NISMO_R6 For This Useful Post:
BCBrian (10-29-2012)
Old 10-29-2012, 05:50 PM
Sly Tuna's Avatar
Feedback Score: 5 reviews
Good thread. EXTREMELY IMPORTANT! I also use hot pepsi and a brush (Rinse with water afterward.) I like to coat it with the red terminal spray.
2011 Frontier S. KC. 5spd. White.
Tinted Windows, Bed Liner, 1-1/4" Wheels Spacers, Bully Dog-Triple Dog GT with blend mount.
The Following User Says Thank You to Sly Tuna For This Useful Post:
Old 10-29-2012, 05:54 PM
BCBrian's Avatar
When the ECU fried, I had the truck towed to the dealer. They had to cut the terminal off the cable and replace it. The spray is anti corrosive terminal spray and it really never dries. I believe you can get it at any Auto Parts store.
Zedbra (10-31-2012)
