  #21 (permalink)
Old 05-01-2008, 11:52 PM
I like the bottle of Mother's detailer on the tire. That stuff works pretty good. The Ultimate Detailer from Mequiars works good too. Was that a sponsorship shot or just showin off?
-Jason
06 SE KC 4x4 - Black
  #22 (permalink)
Old 05-02-2008, 04:17 AM
frontpagenews's Avatar
I threw that in there for fun...I like fun. Besides, it shows how much of a lift there is for anyone else with bucket contact...
Plus when you look at the picture, you gotta ask yourself, "Now what exactly am I looking at?"
Thanks BlackTigerSE, I was hoping the washers would provide enough support to keep the bump stop from getting annihilated due to the recessed plate and raised UCA edges.
  #23 (permalink)
Old 06-02-2008, 11:24 AM
BlackTigerSE's Avatar
This does wonders! I "fudged" up my truck pretty bad on my last off road adventure and they held up nicely until one decided to fall off on me. The coil bucket without the bumpstop inflicted a lot of damage. The arm actually dug into the bucket, which is going to leave a very noticable scar, haha. The other coil bucket with the bumpstop had no further dings, dents, paint peal, etc. They hold up very well and im thinkin' about upgrading to a 3" lift now that i got rid of that "clunk" sound. Oh and go with wing nuts, the install is easier and make sure you get it on TIGHT! Or else the nut will unscrew itself overtime and fall off just like mine.
SE KC 4x4 6M M226 3.538
  #24 (permalink)
Old 06-02-2008, 04:23 PM
06blackse's Avatar
Can you use Loctite? just a dab should do the trick or the aircraft nut that comes with the bump stop?
Current Collection:
06 Honda Civic EX (SI swap w/turbo, wifes car)
06 Nissan Frontier SE King Cab
(3" PRG, Pro comp 8089 Wheels, Procomp Extreme Mud Terrains 285/75/16, AFE Stage 2 Intake system...Future mods to include: Banks Monster Exhaust system, Unichip tuner w/flux display, TB spacer)
  #25 (permalink)
Old 06-06-2008, 06:38 PM
Anyone have the part number on this stop?
  #26 (permalink)
Old 06-07-2008, 02:09 AM
Pappa John's Avatar
I love how the bump stops are working! Instead of the wing nut I used a "tap" and tapped teh uca after I drilled it out. Worked like a champ! On the other uca I accidentally drilled too much out so I just used teh nut that came with the bump stop, and after a few hundred or so miles it is as tight as can be. This was the best idea I have heard in a long time. Thank you for posting it. It solved alot of the suspension issues.
  #27 (permalink)
Old 06-09-2008, 11:20 AM
Edit: Wing Nuts do not work for me...too big.
I bought 99132G
While we find your parts, please enter your ZIP Code at PartsAmerica.com
If the bump stops start to rip and tear from the sharp edge of the UCA overtime, then install washers under the bumpstop to extend the height.
  #28 (permalink)
Old 06-13-2008, 10:54 AM
Yep, I've got three washers (don't remember the thickness, but I'm guessing 1/8" each) to get the bumpstops to the correct spacing away from the UCA.
My wingnuts helped me out last night...only took a minute to uninstall the 3/8" stop and install the 11/16. It really helps if you take a stubby screwdriver and thread it through the top of the UCA, through the wingnut, then through the bottom of the UCA, start threading the bumpstop from below and let the wingnut catch itself. It takes little to no effort.
Reason for switching: The passenger side bucket got a few scratches so I am hoping a swap will handle the situation. If not, I will drill out the second hole and that should definitely do.
I will update with the results from the 11/16" after a few big bumps.
  #29 (permalink)
Old 06-13-2008, 11:31 AM
Autospirit's Avatar
Yeah let us know when you find something that works. It seems a lot of you guys are trying different variations, 3/8 vs 11/16, one hole vs another, washers, etc...
BTW frontpagenews, what is your lift height? You have Radflos cranked up to ~3"??
07SECCSB4X
  #30 (permalink)
Old 06-13-2008, 04:42 PM
Well i lifted my truck and the contact point is perfect for me. The bumpstop is doing its job...ill take pictures when i finish making my custom skid plates and install them.
