  #31 (permalink)
Old 06-13-2008, 06:04 PM
frontpagenews's Avatar
Originally Posted by Autospirit View Post
Yeah let us know when you find something that works. It seems a lot of you guys are trying different variations, 3/8 vs 11/16, one hole vs another, washers, etc...
BTW frontpagenews, what is your lift height? You have Radflos cranked up to ~3"??
The front lift (all done by BRUTAL) is CST spindles, Radflos cranked to maybe 1", and regular old 265/70/16 Michelin AT2.
I am sure I could crank them up again, but at the cost of less down travel and a stiffer ride.
  #32 (permalink)
Old 06-20-2008, 04:12 AM
07Nismo4x4's Avatar
I ordered some bump stops for the UCAS got them in a few days ago...hope they work they arent black they are red and look a little thicker then the ones in the pics on the thread...but that might be better idk.....i will get them on this weekend and post some pics.......anyone else got these on yet???
07 Nismo 4x4,Storm Gray,Rear Locker,SunRoof,RockfordFasgate/Sub,i-Pod Hook Up,Tow Pkg,Nismo Skids,PRG 2-Spacer/2-Block,Rear 5125's,BFG A/T 265's,K&N 63 Ser.Intake,MagnaFlow,Front windows Tinted,Front Badge Painted Black...
.......________
____l_l__,\___\,__
l---_l_l_---_[=lllllll=]
()_)'' ``()_)--''--)_)
GOD BLESS THEU.S.A. !!!
  #33 (permalink)
Old 06-25-2008, 01:18 AM
Well, after running the 11/16" bumpstops for awhile, I've concluded that they've done the trick for my setup...CST Spindles/Radflos. Here is a pick of the spot where the bumpstop rubs the bucket on full droop.
Good $15 solution until I can pick up some PRG UCAs.
Hard to see, but if you look, you can make out a semicircle to the right of the nut (that belongs to the coilovers).
  #34 (permalink)
Old 06-27-2008, 12:45 PM
The darker black on the bucket to the left of the rectangle is just touchup paint from the numerous contacts.
