  #41 (permalink)
Old 01-26-2007, 10:22 PM
Phil'sFrontier's Avatar
try it, worked. Cool. Thanks peeps!
  #42 (permalink)
Old 07-18-2007, 01:33 PM
Devious
Posts: n/a
Great info! Worked like a charm. I have not found the codes for the light blinks it gives off but, since I knew what my problem might be I was able to fix my problem and use this info to clear the codes out of the ECM. Most of the auto part stores around me will not clear the codes from the ECM even if you did fix it yourself.
  #43 (permalink)
Old 01-11-2008, 01:50 AM
Johnnyman88's Avatar
are you guys fixing codes with those scan guages??
  #44 (permalink)
Old 04-02-2008, 12:02 PM
d60tab's Avatar
Good Info! Nice work!
2008~CrewCab~LE >>> Storm Grey~Steel Cloth
Acc./Mods >>> Bed Extender~Tow Package~JVC KW-XG700
  #45 (permalink)
Old 04-14-2008, 12:22 AM
Exclamation p0325 knock sensor
[quote=RedAlert;62447]Talked to a friend who has access to an alldata. Heres a short list of codes he sent me. Hope this helps everyone out.
P0325 Knock Sensor, Bank 1
Hello im new here but i have a question on the knock sensor and since you mentioned you have a friend with that has a list of the codes i was wondering if you could help me out. I bought a frontier a week a go and ran the obd2 scanner and came upon this code p0325 i know it the knock sensor but can some one tell me where it is located and what it affects in the truck?
  #46 (permalink)
Old 05-12-2008, 09:53 PM
Nismo54's Avatar
Someone else may be able to help you more, but here's what is in the service manual.
06 SB NISMO KC
OE Hood Protector/Step Rails/Rubber Mats, AVS Ventshades, Extang Trifecta, CoverKing Dashmat, 30% Tint, SilverStars, AC Shackles, Keyless Entry Pad, RT QuickLIFT Plus, Tailgate Power Lock Mod, Airbox Mod, GD Opener Mod, EZDown Tailgate Mod
  #47 (permalink)
Old 05-28-2008, 12:08 AM
Unhappy Thank
Thank but now i have a different problem. My truck wont start i think its the switch although i ran the obd again and it cam with p1605. again i need help anyone ??????
