  #21 (permalink)
Old 10-23-2006, 04:05 AM
masteryoda13's Avatar
this is very interesting and useful information...thanks for the heads-up...
For over a thousand generations, the Jedi Knights were the guardians of peace and justice in the Old Republic. Before the dark times, before the Empire.
_________________
2005 Nismo CC 4x4, Valley Hitch, Alpine Headunit w/ Aux input for iPod
  #22 (permalink)
Old 10-23-2006, 05:15 AM
1stNismo's Avatar
WTF! My truck doesn't have VDC, or hill decent assist but when I do the light test the lights are still active. or does the truck still have those features but no switch to turn on/off. Would a relay and a set of switches give me HDA, and VDC?
'06 CC Nismo 4X4 K&N filter, air box mod, silverstar lights, fog light bypass mod, nissan tool box, Passport 8500 X50 radar detector, sliding bed extender, 20%tint on all windows
  #23 (permalink)
Old 10-23-2006, 05:18 AM
shift_this's Avatar
i noticed the same with mine. im sure they put all the same guages in all of them. they arent going to go and make 2 different versions just to eliminate 2 led's. it is cheaper and easier to just put the same guage cluster in all of them...
  #24 (permalink)
Old 10-23-2006, 05:29 AM
1stNismo's Avatar
I figured that but I was hopeing.
  #25 (permalink)
Old 10-24-2006, 05:17 PM
Nismo54's Avatar
As stated in the Service Manual
SELF-DIAGNOSIS FUNCTION
The following items can be checked during Combination Meter Self-Diagnosis Mode.
 Gauge sweep and present gauge values.
 Illuminates all odometer/trip meters and A/T indicator segments.
 Illuminates all micro controlled lamps/LEDs regardless of switch position.
 Displays estimated present battery voltage.
 Displays seat belt buckle switch LH status.
HOW TO INITIATE COMBINATION METER SELF-DIAGNOSIS MODE
NOTE: Once entered, Combination Meter Self-Diagnosis Mode will function with the ignition switch in ON or START. Combination Meter Self-Diagnosis Mode will exit upon turning the ignition switch to OFF or ACC.
To initiate Combination Meter Self-Diagnosis Mode, refer to the following procedure.
Turn the ignition switch ON, while holding the odometer/trip meter switch for 5 - 8 seconds.
NOTE: If the diagnosis function is activated the odometer/trip meter will display tESt. Push meter switch for each test.
Next test requested GAGE
Performs sweep of all
gauges, then displays
Performs checksum tests
on ROM and EE.
Gauges sweep within 10 seconds
Next test requested (All segments illuminated)
Lights all odometer/trip
meter segments.
Next test requested bulb
Illuminates all micro-controlled
lamps/LEDs
regardless of SW configuration.
Odometer/trip meter A/B
switch engaged and
released = next test
requested
rXXXX, FAIL
Return to normal operation
of all lamps/LEDs and
displays hex ROM rev. If
a ROM checksum fault
exists, display alternates
between "r XXXX" and
"FAIL".
Next test requested nrXXXX
Displays hex ROM rev as
stored in NVM.
Next test requested EE XX, FAIL
Hex EE level. If EE
checksum fault exists,
display alternates
between "EE XX" and
"FAIL".
Next test requested dtXXXX
Hex coding of final manufacturing
test date.
Next test requested Sc1XX
Displays 8-bit software
configuration value in Hex
format.
Bit Coding
7-3 = reserved for future use
2 = TCS/VDC 0 = not present
1 = present
1 = Shift type 0 = Column shift
1 = Floor shift
0 = ICC 0 = not present
1 = present
Next test requested Sc2XX
format.
Bit coding
7-0 = Reserved for future use
Next test requested EprXX
format.
Bit Coding
7-2 = reserved for future use
1 = A/T Oil Temp (gauge)
0 = not present
1 = present
1 = Odo Units 0 = kilometers
1 = miles
Next test requested 1nFXX
Displays 8-bit market info
value in Hex format.
$31 = USA
$2A = Canada
Next test requested cYLXX
Displays 8-bit engine configuration
value in Hex
format.
$08 = 8 cylinder
$06 = 6 cylinder
Next test requested FFXXXX
Displays 16-bit fuel flow
constant "Q" in tenths of
cc/min in Hex format.
$0000 - $FFFF
Next test requested tF
Displays 16-bit tire factor
"A" in hundredths in Hex
format.
$0000 - $FFFF
Next test requested ot1XX
Displays oil pressure telltale
"on" threshold in A/D
counts in Hex format.
$00 - $FF
Next test requested ot0XX
"off" threshold in A/D
$00 - $FF
Next test requested XXXXX
Raw uncompensated
english speed value in
hundredths of MPH.
Speedometer indicates
present speed.
Will display "-----" if message is
not received. Will display
"99999" if data received is
invalid
Raw uncompensated
metric speed value in
hundredths of km/h.
present speed.
invalid
Next test requested tXXXX
Tachometer value in
RPM. Tachometer indicates
present RPM.
not received.
Next test requested F1 XXXX
Present ratioed fuel level
A/D input 1 in decimal format.
Fuel gauge indicates
present filtered level.
000-009 = Short circuit
010-254 = Normal range
255 = Open circuit
--- = Missing 5 seconds
Next test requested XXXC
Last temperature gauge
input value in degrees C.
Temperature gauge indicates
present filtered temperature.
Will display "---"C if message is
not received.
Will display "999" if data
received is invalid.
Next test requested BAtXX.X
Estimated present battery
voltage.
Next test requested rES -X
Seat belt buckle switch
LH status.
1= Buckled
0 = Unbuckled
Next test requested PA -XX Hex value port A.
Next test requested Pb -XX Hex value port B.
Next test requested PE -XX Hex value port E.
Next test requested PL -XX Hex value port L.
Next test requested P6 -XX Hex value port K.
Next test requested Pn -XX Hex value port M.
Next test requested PP -XX Hex value port P.
Next test requested PS -XX Hex value port S.
Next test requested Pt -XX Hex value port T.
Next test requested Pu -XX Hex value port U.
Next test requested P4 -XX Hex value port V.
Next test requested Puu -XX Hex value port W.
Next test requested A01XXX
A/D port A/D value (nonratioed).
0-255
Next test requested A02XXX
0-255
Next test requested A03XXX
0-255
Next test requested A04XXX
0-255
Next test requested A05XXX
0-255
Next test requested A06XXX
0-255
Next test requested A07XXX
0-255
Next test requested A08XXX
0-255
Next test requested A09XXX
0-255
Next test requested A10XXX
0-255
Next test requested A11XXX
0-255
Next test requested A12XXX
0-255
Next test requested A13XXX
0-255
Next test requested A14XXX
0-255
Next test requested A15XXX
0-255
Next test requested PA0-XX
Hex value representing
state of A/D ports 0-7.
Event Odometer Display Description of Test/Data Notes:
DI-16
Next test requested PA1-XX
Return to beginning of self-diagnosis.
06 SB NISMO KC
OE Hood Protector/Step Rails/Rubber Mats, AVS Ventshades, Extang Trifecta, CoverKing Dashmat, 30% Tint, SilverStars, AC Shackles, Keyless Entry Pad, RT QuickLIFT Plus, Tailgate Power Lock Mod, Airbox Mod, GD Opener Mod, EZDown Tailgate Mod
  #26 (permalink)
Old 10-24-2006, 05:42 PM
Mylt1's Avatar
so unlike posted before it will not give you SES/CEL codes.
05 LE CC 4X4. SUPER BLACK
  #27 (permalink)
Old 10-24-2006, 08:37 PM
Nismo54's Avatar
I guess, that's all the service manual says it will give you. Anything else you'll have to use a CONSULT-II.
06 SB NISMO KC
  #28 (permalink)
Old 10-24-2006, 10:54 PM
Mylt1's Avatar
i found out how to pull codes.
  #29 (permalink)
Old 10-24-2006, 11:07 PM
JoshuaTest's Avatar
Thats quite a bit of GREAT info.....
Off Topic
  #30 (permalink)
Old 10-24-2006, 11:08 PM
bwarren228's Avatar
This should be made a sticky!
Third Coast Nissans official page on Facebook
2005 Nismo CC: Titan Swap'd, Bilstein 5125's, BFG MT's, Shrock sliders, White Rhino light bar, Hella 500's, 2* Adv., Magnaflow exhaust, Airaid intake, Stillen rotors,
Metal Matrix pads, Graphite wheels, Manik TL guards, Kenwood DD HU, Sirius, Infiniti 12 and tweeters, 600w amp, in-channel vent visors, Pathfinder switch covers
FUTURE MODS: Wouldn't you like to know!
