try it, worked. Cool. Thanks peeps!
Great info! Worked like a charm. I have not found the codes for the light blinks it gives off but, since I knew what my problem might be I was able to fix my problem and use this info to clear the codes out of the ECM. Most of the auto part stores around me will not clear the codes from the ECM even if you did fix it yourself.
are you guys fixing codes with those scan guages??
Good Info! Nice work!
2008~CrewCab~LE >>> Storm Grey~Steel Cloth Acc./Mods >>> Bed Extender~Tow Package~JVC KW-XG700 |
[quote=RedAlert;62447]Talked to a friend who has access to an alldata. Heres a short list of codes he sent me. Hope this helps everyone out.
P0325 Knock Sensor, Bank 1 Hello im new here but i have a question on the knock sensor and since you mentioned you have a friend with that has a list of the codes i was wondering if you could help me out. I bought a frontier a week a go and ran the obd2 scanner and came upon this code p0325 i know it the knock sensor but can some one tell me where it is located and what it affects in the truck? |
Thank but now i have a different problem. My truck wont start i think its the switch although i ran the obd again and it cam with p1605. again i need help anyone ?????? |
