Tire jack options or High lift? - Nissan Frontier Forum
 1Likes
post #1 of 17 (permalink) Old 01-09-2017, 01:58 PM Thread Starter
Arthur_C's Avatar
Quoted: 235 Post(s)
After i lifted my truck, i pretty much realised that the jack that i got from factory is pretty much useless to me after my 3 inch lift with my 33's.
I am looking for a High lift jack for my truck but 4 Wheel parts talked me out of it because i do not have a place to put it on the truck to safely jack up the truck in case of a flat.
What do you guys do? What do you guys carry as far as a Jack to replace a tire just in case. Keep a piece or 4x4 wood to pace the jack on top of?
Let me know guys
15 Frontier Pro4-x - The redheaded Problematic step child.
14 Audi SQ7 - The Daily Driver
14 Maserati Ghibli - The weekend cruiser
Build Thread: http://www.clubfrontier.org/forums/f...-build-226257/
Arthur_C is offline
post #2 of 17 (permalink) Old 01-09-2017, 02:17 PM
Grommit's Avatar
Quoted: 64 Post(s)
I do know there are several attachments that can make the hi-lift work. Like wheel attachment jacks and such, but I suppose if you don't have an aftermarket bumper or solid rock sliders on the sides, it would be a bit of a wasted investment. At least for now. As far as lift, yeah a couple short blocks of 4x4 wood is what I use. My 2 3/4 ton floor jack can't even really get the stock pro-4x up off the ground to any respectable height without the wood blocks... They don't exactly sell floor jacks FOR 4x4 specific vehicles either...
SASHA: 2016 PRO-4x Standard. JBA headers, JBA SS exhaust. Tekonsha P3, Shrock diff cover + Lubelocker gasket, Shrock skids. WK sliders, 2" lift up front, 1.5" in back. Cam bolts installed, Sway bar removed.
Grommit is offline
post #3 of 17 (permalink) Old 01-09-2017, 02:32 PM
Administrator
JeniorNV's Avatar
Quoted: 2592 Post(s)
I haven't had a chance to try it out yet but I recently purchased this:
https://safejacks.com/collections/fr...th-bottle-jack
-Jennifer
Suspension Lift Info 05+
JeniorNV is online now
The Following 3 Users Say Thank You to JeniorNV For This Useful Post:
bhowdy (01-09-2017), FlyAKyte (01-31-2017), whistler (01-09-2017)
post #4 of 17 (permalink) Old 01-09-2017, 02:53 PM
J&JPolangin's Avatar
Location: From one cold place at the TOW to another lower cold place...
Quoted: 104 Post(s)
...after reading your OP, I feel sort of stupid that this issue never crossed my mind (although I'm still only in the research phase of what lift and suspension I want to do to my SV CC)...
'17 Frontier CC SV v6/6M 4x4 SB to compliment my TL1Ks and other stuff
...what to spend on first; suspension, armor, lighting?...the mod bug bites hard
J&JPolangin is offline
post #5 of 17 (permalink) Old 01-09-2017, 03:10 PM
Grommit's Avatar
Quoted: 64 Post(s)
Unfortunately I cannot find any screw style bottle jacks on the market anymore. I really want one like my original Datsun truck had. Even some Toyota's had them in the 90's and early 2000's. Sadly the only kind of bottle jacks you can find now are the obnoxious and unreliable pump kind. At least those are the two adjectives I use for them, probably great for everyone else.
I do miss being able to just hook the power drill up to the bottle jack and up goes your vehicle.
Grommit is offline
post #6 of 17 (permalink) Old 01-09-2017, 04:54 PM
whistler's Avatar
Quoted: 523 Post(s)
This is what I use. It is a scissors jack for an H1 Hummer.It comes with a steel base that keeps it from sinking in soft terrain.
Did some modifications so it would be secure under the differential. Also welded a lug nut to it so I can use a portable impact wrench to raise and lower it.
We keep "Hi-lift" jacks in the chase vehicles.
ID:	229313   Click image for larger version
ID:	229321   Click image for larger version
whistler is offline
bhowdy (01-09-2017)
post #7 of 17 (permalink) Old 01-09-2017, 05:37 PM Thread Starter
Arthur_C's Avatar
Quoted: 235 Post(s)
i never really cared about that until i really started offroading my truck quite a bit. Had it happen on my last trip with one of my friends in a tacoma and i wanted to make sure i was prepared for it if and when it does happen to me.
Sometimes Triple A or Nissan road side wont come to where you are lol
Arthur_C is offline
The Following User Says Thank You to Arthur_C For This Useful Post:
J&JPolangin (01-10-2017)
post #8 of 17 (permalink) Old 01-09-2017, 05:47 PM
R00
R00's Avatar
Quoted: 267 Post(s)
I carry a Craftsman 12 ton but don't have any of those nifty accessories. I got's me some pieces of wood though...
This guy is super sexy but that's some serious weight to take on when the scissors, bottle, and hi-lifts do the job just as well (and others)
One of the reasons sliders were one of my first investments (other than fear of pinching a rocker panel) was because I knew I'd be toting a Hi-Lift whether I had lift points or not, since it's so versatile. You can get any of four wheels off the ground with sliders, sometimes two. Bumpers don't always lift as well (I need an attachment for the shackle to lift from my front Shrock)
R00
a.k.a. MakTruk
Overland Bound #0912
"Enthusiasm is a dangerous replacement for experience." -- BCBrian
R00 is offline
post #9 of 17 (permalink) Old 01-09-2017, 06:03 PM
Nissan4Life's Avatar
Quoted: 450 Post(s)
It is all about where you jack. In the rear you jack on the axle tube. The half inch going from 32" to 33"s make no difference in getting the wheels off the ground.
In the front it looks like you have SPC UCA thus you have about 1" extra of down travel. Still the factory suspension drops considerably when lifted from the frame. Have you tried. How close. You can jack on the front cross member as that is a bit lower and will get you more height. You can also jack directly on the LCA. THis will lift the truck with no suspension drop to worry about.
Using a high lift to change tires is dicey. The best lift point for a high lift is in the 2" receiver of the hitch. Tongue of the lift fits perfectly. I don't like jacking on the sliders as the top of the lift is too close to the body for my taste. I use a lift mate (hooks on to the wheels) for corner lifting but that doesn't help with changing the tires.
IMO the stock jack is still the best for changing tires. Just have to know where to jack from.
06 KC NISMO 4x4 6sp
Nissan4Life is offline
mtyler11 (01-09-2017)
post #10 of 17 (permalink) Old 01-09-2017, 06:12 PM
glamisdude's Avatar
Quoted: 500 Post(s)
^This. Under the axle tube or LCA the factory jack does just fine for tire changes. For off road I just throw a block of wood to help the jack reach if those spots are inaccessible.
-Chris
2007 KC NISMO-4X Auto Jan 2013, Apr 2015 TOTM
2005 KC SE Auto 4x2 Totaled, missed, loved
Off Roadish Popup Camper Build
Audio Questions? , Torque Specs, TITAN SWAP GUIDE, Have a question? PM me
glamisdude is offline
