» Sponsors
» Sponsors
Old 03-19-2008, 11:34 PM
Originally Posted by collinsz View Post
I live in Columbia, MD. I sent you a PM..
I have family in Elkridge which I believe is fairly close. I just might need to see the rack installed in person next time I come down there. It does look good.
Old 03-20-2008, 12:27 AM
timman_24's Avatar
Nice. I think I like that more than the stock rack that comes with the crew cabs. Your's isn't nearly as bulky looking.
2006 Nismo KC Auto 2wd
Hard stuff: 4" CST lift | 2" block | 285/70-17 Kumho A/Ts | 17" MB Motoring 72's
Fun Stuff: 10" CDT Audio sub | PG Tantrum amp | Tint
Check out my replica Lotus Super 7 Build http://locost.wordpress.com
Old 03-21-2008, 04:05 AM
Johnnyman88's Avatar
is there a way to not cut a hole through the roof to put the tracks??? any ideas??
Calmini Kit W/ PRG Ext. Radflos
TC UCA's(would trade for prgs)
AC Body lift
WRP GK
JBA Catbak Sys. & AEM CAI
www.Discounttiredirect.com
Old 03-21-2008, 06:40 AM
3M makes a double sided tape that has a thin foam in the middle. This tape is often used to hold the sheet metal to the frame in truck trailers and to build small metal shelters like those at bus stops. Obviously, these are metal to metal bonds that see a lot of heat, cold and water yet they seem to hold up quite well over long periods of time. On a roof rack, the only shear forces would be the wind load from any cargo carried.
Seems to me that such a tape would be satisfactory in holding down a metal strip to the roof providing that the strip has a flat underside that would be in direct contact, not with a raised middle section (inverted U) that would prevent good contact.
Old 03-21-2008, 09:04 AM
collinsz's Avatar
Come and check it out whenever, shoot me a PM.
Honestly, if you have reservations about drilling in your roof I understand. I was freaked out. Im not a very mechanically oriented person, and I managed to do it with no problems. The hardest part is drilling the first hole.
2008 Nissan Frontier Crew Cab 4X4 SE
mods:
-AVS bug/wind deflector
-Thule Roof Rack
-Pioneer FH-P8000BT
-more to come
Old 03-21-2008, 03:59 PM
drobs's Avatar
Looks good!
Stock 2006 SE King Cab 4x4
Old 03-21-2008, 04:41 PM
I'd be a bit hesitant of using tape because on a hot summer day won't the adhesive soften and the wind againt a load help to lift the rails front the front to back? To me as long as you use sealer to prevent leaks and the sheet metal from rusting this is a beautiful option. As I said before I would have bought an SE, saved money in the process too and got the six speed trans that I prefer to drive.
Old 03-25-2008, 04:34 PM
rockclimbingpyro's Avatar
Send a message via Skype™ to rockclimbingpyro
how did you keep from not going all the way through to the headliner? just the very carefully method?
2006 4x4 CC SE, Stock Suspension, Leer Browning Special ed. Shell with Thule Rack and locking gun box. BFG ATs with Nitrogen.
4 Infinity Kappa 60.7cs components, custom tweeter mount in rear doors, 4-channel Infinity Ref475A, Pioneer Avic-D3 bypassed with bluetooth and i-pod interface.
Future: Sub and Amp, Mounted Inverter, Thule Rack on the Cab of the Truck, and plenty more i dont need to think about right now
  #19 (permalink)
Old 07-07-2010, 05:21 PM
Thule Roof Rack Install, by Collinsz
WOW, that is an impressive job. I bought a 2008 Frontier King Cab w/o a roof rack and have been looking for a way to install a safe and secure rack to carry 2 kayaks. I think this it. Did you find the rack on-line? Where did you find the best price? Thanks for the photos and great info.
BIOA
