Ok i just found this looking for a relay harness and its a multi relay/fuse block. i was going do buy the hella boxes and pair them but this is cheaper, pre wired and comes complete with fuses/relays.
5 relays with 30 amp fuses each
5 accessory runs with 15 amp fuses each.
each run bundle has is own split loom harness cover
power ground cable 36in
relay runs color coded 36 in
power supply from relay and accessory runs color coded 36in
price will be $130 listing is promised to be up sat night. and link will be posted then.
