Cam bolts
It would be nice if the cam bolts were included in the kit as well.... |
nice write up...subscribing
My Garage: 2008 4x4 CC SE LB - huntin',fishin',muddin' 2008 Toyota Prius - suit and tie 2008 Toyota Rav4 - wife 2006 Yamaha R6 - WERA/CCS #447 2003 Honda S2000 - SCCA #44 |
was wondering when you were doing the deaver kit did you need longer U-bolts for the axle?
I did the 2 inch deaver aal and used the stock ubolts.
alright cool thats the same setup that i have on the way and was hoping to hear that...
I installed the deaver springs and took out the overload leaf spring. I will be using the truck to tow a 3000lb car on a u-haul trailer. I know the rear will sag alot because the overload leaf spring is off.
Is it possible to reinstall the overload leaf springs and keep the deaver springs? |
nice write up!!!
I have some question: - Do you have stock shocks front / rear ? - all is still OK ? Thanks |
If you do plan on replacing your front shocks you might as well go with a larger set of coilovers for the lift and ditch the spacers all together.
front: for stock coilover and shocks is safe 1,75" spacer (3" BL) ? Or how many
rear: shackle or spacer ? heigh 2" spacer is safe ? How long shackle ? Thank you very much, I am green |
| Thread Tools | |
| Display Modes | |
