  #51 (permalink)
Old 07-11-2008, 01:33 PM
JMD's Avatar
JMD JMD is offline
I'll add a few tips from my experience.
1. Use PB Blaster Penetrating Catalyst to remove old bolts (thanks CF members), WD-40 sucks
2. If the ball joint does not release right away hit the front of the spindle a few times then the UCA, then the spindle, UCA, ...
3. Do not use a 1/2" to 3/8" adapter on your socket wrench to try and remove the lower shock bolt, you will break it
4. Use a better under-truck lighting than a flashlight
In the end it all went together, but it was a real pain to get some of the bolts on and off. It should be noted though that I have had my truck for three years and 80,000 km so the bolts were a little rusty.
'05 SE CC 4x4 Silver 6sp
Planned Summer Mods - billet grille
Current Mods - ARE color-matched topper, alarm/remote start, NISMO CAI, Chrome OEM handles, gunmetal 6sp shift knob, 18" Gunner 6s w 275/65/18 Bridgestones, 2" PRG
  #52 (permalink)
Old 07-21-2008, 02:23 AM
jaws8817's Avatar
Cam bolts
Originally Posted by UGA Frontier View Post
Did you guys rush right out to the alignment shop afterwards or was everything still pretty good?
Yes, I went right to Sears and got it aligned. The instructions, for all their simplicity should include a line about the importance of proper alignment.
It would be nice if the cam bolts were included in the kit as well....
  #53 (permalink)
Old 07-29-2008, 09:39 PM
nice write up...subscribing
My Garage:
2008 4x4 CC SE LB - huntin',fishin',muddin'
2008 Toyota Prius - suit and tie
2008 Toyota Rav4 - wife
2006 Yamaha R6 - WERA/CCS #447
2003 Honda S2000 - SCCA #44
  #54 (permalink)
Old 08-14-2008, 06:55 PM
Bucky06's Avatar
Send a message via AIM to Bucky06
was wondering when you were doing the deaver kit did you need longer U-bolts for the axle?
  #55 (permalink)
Old 08-14-2008, 09:11 PM
EB_05_NISMO's Avatar
I did the 2 inch deaver aal and used the stock ubolts.
  #56 (permalink)
Old 08-16-2008, 12:30 AM
Bucky06's Avatar
alright cool thats the same setup that i have on the way and was hoping to hear that...
  #57 (permalink)
Old 11-19-2008, 02:16 PM
Clips97's Avatar
I installed the deaver springs and took out the overload leaf spring. I will be using the truck to tow a 3000lb car on a u-haul trailer. I know the rear will sag alot because the overload leaf spring is off.
Is it possible to reinstall the overload leaf springs and keep the deaver springs?
  #58 (permalink)
Old 11-20-2008, 08:29 AM
nice write up!!!
I have some question:
- Do you have stock shocks front / rear ?
- all is still OK ?
Thanks
  #59 (permalink)
Old 11-20-2008, 12:22 PM
TerribleOne's Avatar
Originally Posted by HonzaM View Post
nice write up!!!
- all is still OK ?
Thanks
If you are lifting more than 2" in the rear it's a very good idea to get slightly longer shocks. Up front you can retain the stock coilover if desired...the spacer sits on tip of the coilover and doesn't effect shock travel so there is no NEED to replace it.
If you do plan on replacing your front shocks you might as well go with a larger set of coilovers for the lift and ditch the spacers all together.
  #60 (permalink)
Old 11-20-2008, 03:53 PM
front: for stock coilover and shocks is safe 1,75" spacer (3" BL) ? Or how many
rear: shackle or spacer ? heigh 2" spacer is safe ? How long shackle ?
Thank you very much, I am green
