Old 01-24-2008, 06:08 PM
Mylt1's Avatar
sorry i couldnt post earlier. i got banned for 7 days for defending myself. looks good and glad i could help.
05 LE CC 4X4. SUPER BLACK
Old 01-24-2008, 07:38 PM
BoyInBlue2658's Avatar
just out of curiosity, why not just spend $50 for one that plugs into the power outlet? is there some kind of benefit to using this one?
R.I.P LAPD Ofcr. Randy Simmons "R 41 david" EOW 2/7/08
Old 01-24-2008, 08:18 PM
CraneWR's Avatar
Send a message via AIM to CraneWR
I ones that plug into the power outlet can only deliver 400w max, that is if your lucky. Most can't do it unless directly connected to the battery anyways. This way the inverter doesn't work as hard since its an 800w, and you have enough juice if you need it. So I by-passed all the pain in lugging it around in the truck and plugging it in when need and I went the more convenient route.
It actually wasn't that hard to do. Check out the other Post "WRITE UP and Pics of Inverter under front seat"
'07 Majestic Blue Nismo, CC ,4x4, Rockford Fosgate System, Sunroof, Chrome Mirros & Door handles
Mods: K&N Filter, Part of Silencer Tube Removed, TB bypass; Lund Soft Bed Cover, Grounding Kit, 800/1600w Power Inverter under driver seat, No Tinting, I'm to pretty too hide.
http://www.myspace.com/wescrane
Old 02-11-2008, 04:30 PM
calimobber's Avatar
Send a message via AIM to calimobber Send a message via Yahoo to calimobber
I know im way late ,but been away for a while. Great job looks awesome. Mine comes in handy all the time, Used it to power laptop on my cross country drive. Just dont forget to turn it off, I killed my battery because i forgot to turn off the laptop and it slowly drained the battery all night.
Its only an offroad truck if you take it off the road.
10" Alpine sub/Alpine 400 rms amp, ScanGauge 2, Fog Lights, Clutch bypass switch, Hardwired 400w inverter, Back-up lights, Reverse Lights on/off/norm switch, Shackle Lift with helper Springs.
99 Frontier KC XE 5spd 2wd manual everything
Old 03-03-2008, 08:35 PM
TheRealDoug's Avatar
nice job, but one question - wouldn't it be better to put the fuse closer to the battery? I've always though you put the fuses as close the battery as possible.
Lets say for some reason the cable gets pinched at the firewall and creates a short. THe fuse blows so it doesn't fry your inverter. but its still got a a shor from the battery to the pinch point...
-d.o.u.g-
I've got one in the chamber
and two in the clip; doing
what i can to die on my feet.
08 Blue CC LE 4x4. Mods: dirt.
Old 03-04-2008, 12:18 AM
Mylt1's Avatar
i think he used an amp wiring kit which would have a fuse at the batt. i could be wrong.
Old 03-08-2008, 11:40 AM
CraneWR's Avatar
Wire answer
I did use an Amp kit, But i did not fuse it near the battery. I wanted to keep the unit in the set up that it is. I'm not worried about pinch the cable because it is quite think and the route I ran it keeps it away from moving parts and tight corners. the fuse I used in the DB is a bit lighter than the fuse on the inverter so they should blow first. I may add a fuse one weekend once Lacrosse season is over.
But no problems so far.
Old 03-08-2008, 05:07 PM
yeah, it may be thick, but i've seen with my own eyes a $20,000 car with who knows how much money into the audio system burn to the ground because a 2awg wire rubbed a small hole in its sheath.
i'm just looking out for ya, man. that's all....
-d.o.u.g-
  #19 (permalink)
Old 03-08-2008, 05:51 PM
roc_my_tims's Avatar
man i forgot to do this mod, now i got an amp going under that seat, oh well maybe later some how.
07 white se CC
changed interior lights to blue bulbs,changed antenna to 12 inch rubber, bakflip cover
  #20 (permalink)
Old 03-09-2008, 03:57 PM
Mylt1's Avatar
you really need to fuse the wire at the battery.
The Following User Says Thank You to Mylt1 For This Useful Post:
Zero Six LE (03-09-2008)
