So your getting a P0463 code, and your fuel gauge is whack. Time for a new fuel sending unit! You can go to the dealer, and get a new fuel pump assembly, installed for about $500. OR you can just replace the sending unit (which Nissan doesn't support doing, they want to replace the entire package)
Here is the write up how, done by Darkness1:
Originally Posted by darkness1
so today i finally fixed my fuel level sensor. i can pass emissions. i am so happy i did not spend crazy dealership prices to get it fixed. for $85 and a couple hours you too can fix this problem. not $400-$500 like they want you to. attached or some pics to help you out as you go along.
1. jack up driver rear side and remove tire
2. disconnect fuel and electrical lines to tank
the one electrical line will require two small screwdrivers to undo the clip
3. remove 3 bolts on the straps that hold the tank in place
4. slowly drop gas tank down ( less gas the easier to drop) me and a friend could hold it with one hand each not that bad at all
5. unclip electrical harness at top of sending unit (do not disconnect the fuel line because gas will come out. learned the hard way. lol.
6. with hammer and screwdriver, spin the locking ring on top to align the locking tabs/grooves and remove. (some spray lube helps)
7. pull out sending unit completely from tank
8. the sensor is on the very bottom unclip 2 harness and it slides off the unit
9. replace with new fuel level sensor
fuel level sending unit part # 25060-zs00a bought online at CourtesyNissanparts.com for $85 including shipping
10. follow steps in reverse to assemble back together
and your done. and yes it really is that easy. took me about 2 hours to do and i think i spent more time drinking then working. so good luck to all and hope this helps.
NOTES: there was not enough room to reach the sending unit so you have to drop the tank first to gain access to the top. there was about a quarter tank of gas in there when I did it. I used the same o ring took a lil bit of the hammer to spin on tight again but it worked fine. and i did disconnect the battery. and my light has yet to come back on.and to let everyone know i passed my emissions with no problems today.
SirLurksAlot
Reason: edited step 6. for clarity and a tip
The Following 21 Users Say Thank You to Inyourface1650 For This Useful Post:
thread looks great inyourface. thank you for the help. i hope this helps others out who want to do it themselves. this was supposed to be for your fuel level sensor but i guess you could replace the whole sending unit if needed. i do not have the whole part number for that though. it has a locking ring not an o ring just to clarify. you can make it out in the pics.
The Following 4 Users Say Thank You to darkness1 For This Useful Post:
did mine today (SES light turned on at 39.9k miles, P0430 code). followed IYF's DIY. took me 30 mins from gathering tools to putting them up (in the shop). it's extremely easy and very straightforward. anyone apprehensive about doing it should not be. all you need is a 17mm socket, a 10mm socket and a screwdriver/punch with a hammer for the lock ring. thank you very much to IYF for a thorough walkthrough of the process. only thing that i would add to it is that the lock ring spins counterclockwise. i almost started to go the other way but then figured it out (clockwise). that is not in the instructions. no biggie, just thought i'd mention it
p.s. the part # in the DIY is no longer valid (according to my dealer). there is a superseded part now that has a different part #25060-ZS00A. i'm hoping that means they fixed the problem with them
NEW MEMBERS MUST post in the New Member Intro forum first to unlock their account.
