  #21 (permalink)
Old 04-14-2006, 12:37 AM
Banned
Send a message via MSN to Frontin
yeah i had some posted in other threads but heres a few random pics with the black rims again
they dont look as pretty all dirty, but still rugged
  #22 (permalink)
Old 04-14-2006, 01:59 AM
I wish I had nismo wheels, they look so much better than my SE but I didn't want to dish out extra money for them.
Legion again with great advice, I wish you were around earlier to let me know about the XIM primer. Hopefully they hold up.
I do plan on buying a new set of wheels when they make a nice 16" deep dish wheel that fits perfectly. So for now these black SE's will do fine for me
  #23 (permalink)
Old 04-15-2006, 06:27 AM
kilago's Avatar
Nice work Chinaman! Great advice too Legion...pretty cool reading up on this although I don't know if I would try it on my own...esp thinking back to my painting projects from 1st grade...
  #24 (permalink)
Old 05-15-2006, 02:00 AM
konarider's Avatar
Re: HOW TO PAINT WHEELS!
Originally Posted by chinaman
Supplies Needed:
-Dupli-Color Wheel Paint or Dupli-Color Engine Enamel Paint, 2 cans(I used the Engine Enamel Paint in Low Gloss Black). But there are many colors available.
-Dupli-Color Clear Coat, 1 can depending on how many coats
-Scoth Brite Scuff Pad
-Sand Paper 500-1000 grit (I personally used 800grit)
-Any Kind of Degreaser
-Blue Painters Masking tape
-Index Cards
-Something to put under the wheels while painting
Step 1:
Jack up your car/truck and remove wheels. It would be easier if you have a full set of jacks so you can do all four wheels at once or if like me, do two wheels at a time.
Step 2:
Clean your wheels thoroughly with wheel wash and degrease them as best you can. you can clean and degrease your whole wheel inside and out but I just cleaned the outside. Dry your wheels with a clean cloth after wash.
Step 3:
Here's the point of no return. Scrub your wheel down with the scotch brite pad. This was the hardest part requiring alot of elbow grease. You have to scuff up the wheel enough so the paint will stick easier. First scuff and then wet sand with your sand paper. I scuffed and wet sanded every surface of the wheel.
Step 4:
After scuffing and wet sanding, wash thoroughly again making sure your wheels don't have any debris or crap on them. This time let your wheels air dry so you don't get any lint or other stuff on them while using a rag. You could use a blow dryer or a heat gun.
Step 5:
After dried, prep your wheels for paint. Use the blue painters tape and mask off your tire. Then put index cards between the wheel and the tire. Also put something on the ground so you don't get any paint on the ground (newspaper works well but I used olf paper grocery bags).
Step 6:
Start Painting. Shake your can, shake it like a polariod picture. I used 2 light coats of black, letting them dry 15 mins in between coats (you can use as much coats as you want, use your discretion). Wet sand the rough spots after each coat as needed. After the second coat, I put 1 medium coat, letting that dry for an hour. I painted the center caps seperatly from the wheel with the same amount of coats, taking off the nissan emblem.
Step 7:
After an hour, it's time for clear coat. I only used 1 clear coat because I didn't want it to be too shiny. So I sprayed 1 medium coat of clear coat letting that dry for 2 hours. (You can use more clear coat depending on how glossy/shiny you want your wheels).
Step 8:
After 2 hours, remove all index cards and tape and remount, being very carefull while putting the lugs back on. I got some scracthes when I was using the tire iron to tighten the lugs
Finished Product
GOOOOD LUCK!
any specific store were you bought them paint?? thanks!
  #25 (permalink)
Old 06-23-2006, 10:12 PM
yeah my buddy warned me ab out painting them myself, because it might chip and if i where to get a paintshop to do it, like earl schieb its 50 for each rim
  #26 (permalink)
Old 06-25-2006, 02:46 AM
dammnit man! im so tempted, i want to do my own gloss black but damn! im scared i might mess up or ittl mes up in the long run, someone professional shine light to my dilemma!
  #27 (permalink)
Old 06-27-2006, 02:34 AM
kansasfrontier's Avatar
Don't worry about screwing up. Just use more sandpaper if you don't like it and start over.
2005 Silver Nismo CC. Volant CAI, AirRaid TBS, Brushed Aluminum Switch Pates, JBA Cat-back exhaust, Rhino-lined fenders and rockers, Total Chaos Upper Control Arm, PRG Mini Lift Kit, Firestone Destination MT's, Flex-a-lite fan coming soon.
  #28 (permalink)
Old 06-27-2006, 02:41 AM
waht do you mean? that means if i dont like ill have to sandpaper the black paint off again?
  #29 (permalink)
Old 06-27-2006, 02:50 AM
Well not all the way off. You just need to rough up the surface so the paint adheres to the surface well.
  #30 (permalink)
Old 06-27-2006, 12:10 PM
so this XIM what are we suppose to do with it, first sand it down then use XIM then use then black paint rihg?
