ZERO Anti-Sieze on the stock plugs!!! I WAS PISSED!! ...
Arrrgh. Thanks for answering a question that I've not been able to get an answer for anywhere. I'll probably do mine at 30K Miles, even if I just remove them, apply anti-sieze and re-install the same plugs for peace of mind. I'll make a judgement call when I remove them as to replace them or not.
2006 SE CC 4x2 6-Speed 4.0L w/Power Package & ABLS, Red Brawn
Per the service manual, spark plugs need to be changed out every 105k miles. I was wondering why such a long interval. They look easy to do. But seeing this post, I guess I did not look at those other cyclinders.
06 KC NISMO 4x4, 2" prg spacer front, Firestone riderite airbags rear, Schrockwrxs front engine skid, Custom sliders, Hidden hitch reciever, Deck plate Airbox mod/amsoil filter, Momo shift knob removed, back to 06+ nismo knob, 05 pathy flat black wheels, 265/75/r16 Tread Wright Sentinel with Kedge Grip, wireless door lock keypad, cargo light bypass, auto dimming rear view mirror with compass and temp. http://mrpulldown.blogspot.com/
It isnt that difficult, seriously. The upper intake manifold comes off in about 30 minutes. Prob less, I just cant remember. There are 2 bolts on the passenger side and then like 8 bolts inbetween the runners and a couple bolts here and there but its really easy.
My father (registered GM mechanic) told me the iridium/platinum spark plug intervals are a huge headache. He regularly has to bore and heli coil heads to fix seized plugs. A good suggestion he made to me was to take your plugs out and swap them around every 20,000ish km or every 3 oil changes to mitigate the issue. Seems to work pretty good and have never had any issues.
You should be able to do it once every 60,000 miles or so as long as you apply anti-seize to the threads. The plugs have to be removed from a cold engine to avoid damaging the aluminum threads in the cylinder heads.
The Following User Says Thank You to Zero Six LE For This Useful Post:
I just changed the spark plugs on my mothers 05 Xterra it has 103,xxx mile and the plug were pretty wore out but not terrible. The factory laser platinum plugs last that's why there $10 each. Also did the tune up with the a "warm" engine I let it sit for about 45 min. after driving. The Alum heads expands faster than the steel spark plug help make them a little looser. I would not do it on a hot engine or you might just bring the threads out with the spark plug. Also defiantly use anti-seize on the new plugs
Also change the plugs with out removing the intake it is very very tight. If you have fat or large hands there is no way you could change the plugs without removal of the intake manifold. You will need 2 or 3 swivels and a 10mm gear-wrench if you do the plug change without removing the manifold.
2004 Nissan Titan CC LE 4x4, superchips cortex, 2" leveling kit, Air Raid intake
2005 Frontier KC 4x4 SE 6 speed, agri-cover Lorado, 2" front leveling spacer, Jardine cat-back, Air Raid intake, Cortex tuner, Eclipse HU (SOLD)
2003 Nissan Maxima Ti edition 6 speed, 18" Altima SE-R wheels
1989 Jeep Cherokee 2 door 4.5" lift, 31"MT, 8000lb winch
2003 Suzuki Z400 sportquad (SOLD)
2005 Acura RSX Type S (SOLD)
I would not take the manifold if you don't have to. It will reduce the chance of an intake leak later on and the cost of new intake gaskets. But if you don't have small hands I would definitely take the manifold off.
I just bought a frontier with 90,000 and I defintely won't take the intake off it now that I have done on before.
