How-To Change Automatic Transmission Fluid 2005+ Gen 2 - Page 7 - Nissan Frontier Forum
 2Likes
post #61 of 165 (permalink) Old 09-30-2009, 04:07 PM
dubie2003's Avatar
Quoted: 10 Post(s)
Okay, if you are over 30k, then don't flush. If the shop uses an outside source for its pressure, then don't flush. If they reverse flow the system, don't flush.
Basically, don't flush unless you have a bit of warranty remaining.
Nissan also released a TSB stating that their transmissions are designed to work flawlessly without the need for flushing but only draining and filling.
It is up to you thou. It has been documented that flushing the newer auto trans in nissans can cause issues. This happen to Toomnymods on CT and some others. We just havn't seen it a ton yet on the Frontier boards since most don't tow/race as much as the Titans do so we don't piss thru our clutch plates as quickly, lol.
Also, if you insist on flushing, only do it at the dealer so you don't have to worry about warranty claims being denied since you used an outside shop with equipment that isn't up to Nissans standards.
07 SE CC Auto
dubie2003 is offline
The Following User Says Thank You to dubie2003 For This Useful Post:
Zero Six LE (09-30-2009)
post #62 of 165 (permalink) Old 10-31-2009, 01:41 PM
midocr's Avatar
Send a message via AIM to midocr Send a message via Skype™ to midocr
Originally Posted by knocker View Post
Quick question.
I have 06 4.0L. I went to local dealer to buy tranny fluid and they told me they don't make matic J fluids anymore and it's been changed to matic S. Is matic S safe to use on our truck? Dealer guy says it's same, but i don't trust them.
Anybody know the answer to this? What's the difference between the two? I just had the trans service done and they used the type S and couldn't give me a clear answer.
Mike
'05 Electric Blue Nismo CC
"If you're having fun....you're doing it right!"
midocr is offline
post #63 of 165 (permalink) Old 11-04-2009, 05:35 PM
Interesting Technical Service Bulletin from the "Filters Manufacturers Council", basically cautioning about flushing as well...
https://www.amsoil.com/lit/filter_man_council01.pdf
of course these guys are trying to sell filters but it does make sense what they're saying.
2wheelsforfun is offline
The Following User Says Thank You to 2wheelsforfun For This Useful Post:
Geaux504360 (10-04-2014)
post #64 of 165 (permalink) Old 11-04-2009, 05:52 PM
La Queen's Avatar
Quoted: 7 Post(s)
When I was asking a few months ago I wanted to go with the flush because I figured if I change out all the tranny oil he'll be good as new. Well I'm glad I didn't. Called several service shops and asked how often they run a full flush on trucks and how often do people return back with problems. Got the "Eh.. not many.." kinda sheepish reaction A LOT. Go with the drain and fill, thanks guys, lol, he's good as new.
'06 QUEEN CAB 2WD
'16 CC DR
La Queen is offline
post #65 of 165 (permalink) Old 11-04-2009, 06:46 PM
Zero Six LE's Avatar
Quoted: 833 Post(s)
Again, it's referring to transmissions that have not had regular fluid changes as the ones with the problems. I had mine flushed at the dealer with BG synthetic fluid and it's still smooth as butter 2 years later. I don't have any qualms about having it flushed again when the time comes. If flushing was so bad for transmissions, I seriously doubt if my Nissan dealer would provide that service on Nissans still under warranty. There is nothing wrong with drain and refilling but you still end up with a lot of old fluid mixed in with the new fluid at the end of the day.
Zero Six LE is online now
post #66 of 165 (permalink) Old 11-10-2009, 11:44 PM
Excellent write up! thanks for the efforts. Quick question, I am one of those lonely pathfinder owners on this forum, and I don't have the pathy lifted, so what would be the best way for me to drain and gauge the amount of fluid that comes out ? I can't fit a bucket under there, don't really want to put the truck on stands if I can help it. any thoughts ?
2006 Pathfinder LE
2008 Corvette C6
2002 Infiniti I35
kev1n is offline
post #67 of 165 (permalink) Old 11-11-2009, 09:24 AM
Plan on 5 quarts coming out of the pan. 5 qts is equvalent to 1.25 gallons. If you cut the tops off of two gallon milk jugs so they will fit under the pan, you should be good. Just keep an eye on it so the jug doesn't over flow.
To gage the amount of fluid that came out, measure the length and width of the container and how high the fluid is. Then, add that measurement to the other jug (if you used two). Take that number (which will be cubic inches) and divide it by 57.75 and that will be how many quarts of fluid came out.
Ryan B is offline
post #68 of 165 (permalink) Old 11-28-2009, 09:40 PM
Quick question - the manual and the OP calls for warming the car up to Idle before starting. Will the tranny fluid be extremely hot at that point ? Will it be too hot to open the drain plug without burning yourself? Looking to tackle this soon.
2006 Pathfinder LE
2008 Corvette C6
2002 Infiniti I35
kev1n is offline
post #69 of 165 (permalink) Old 11-28-2009, 10:14 PM
Quoted: 833 Post(s)
As long as you don't get it to operating temp by driving it several miles, you should not have to worry about burning yourself. It's a good idea to buy some Nitrile gloves to wear when draining fluids.
post #70 of 165 (permalink) Old 11-29-2009, 04:07 AM
LAWilson's Avatar
Nissan J-Matic is standard Nissan transmission fluid.
Nissan S-Matic is synthetic Nissan transmission fluid.
AMSOIL recommends no flushing, but does suggest to fully replace old fluid with new that we use the bucket method. Remove hoses from the cooler and go from there, already written about here.
If only dropping the pan which is also an acceptable service method, do keep in mind that the trucks come with J-Matic fluid and a pan drop service should have more J-Matic fluid added.
Using synthetic when doing a pan drop service will result in a mixture of fluids that is roughly 60% J-Matic and 40% synthetic. I am unsure if this is a problem, or not ... my local transmission shop recommends that I use more J-Matic or equivelant.
An alternative to using synthetic is to add a friction modifier package such as LubeGuard. I use LubeGuard Black in my transmission and it is a very good addition. For me, this product stopped transmission shuddering and improved shifts.
Read more here: LubeGuard
Change the transmission fluid more often than you think you need to, it is way cheaper than changing a transmission.
I like anything that runs. Cars, trucks, bikes, boats, lawnmowers, etc...
LAWilson is offline
