How-To Change Automatic Transmission Fluid 2005+ Gen 2 - Page 14 - Nissan Frontier / Navara Forum
  #131 (permalink)
Old 11-11-2012, 06:19 PM
GIVE WAR A CHANCE's Avatar
Originally Posted by Zero Six LE View Post
It's funny that the Nissan dealer I go to uses BG products universal ATF with their flush machine if that's the case.
That is pretty funny and a little unprofessional. If I go to a Nissan dealer I want nissan products.
08 fire engine red frontier. 80k mile range. 2* timing advance. OEM NGK iridium tipped plugs. K and N FIPK. Custom intake manifold spacer. Custom Magnaflow catback system with dual pipes/tips (1 in 2 out). Castrol edge w/titanium oil changes, K and N oil filters. Nissan matic S OEM tranny fluid. New BF goodrich OEM T/A tires. Truxedo tonneau. bed liner/extender. Chrome bumpers/grill/tailgate handle.
  #132 (permalink)
Old 11-11-2012, 06:33 PM
Zero Six LE's Avatar
It's a fluid that meets or exceeds some of what has Nissan on the bottle. I don't have any problems with my transmission which is filled with BG Products synthetic ATF. If anything happened to your trans due to the fluid they put in it, they would be on the hook to replace or repair it so you can best believe they would not shoot themselves in the foot.
http://www.ebay.com/itm/BG-3124-Synt...item4169cc0d18
BG Products, Inc.
  #133 (permalink)
Old 11-12-2012, 03:37 PM
jlg2002's Avatar
Ive been just draining the pan and have contemplated doing a flush....whats up with the castrol jlg? Id love to use castrol which is what I use for everything else, but Nissan says not to use anything but their ATF. whats your take on that?
Personally, I think NISSAN is trying to sell overpriced goods. I have 215,000 on my truck and have flushed it using the Castrol ATF maybe 4-6 times so far. The back of the Castrol bottle states it is fully replaceable in place of J-matic.
So if you're under warranty you may want to use the NISSAN fluids to protect yourself. For me I look for aftermarket products that perform as good or better. IMO the Castrol supports my needs.
JLG2002
2005 Frontier LE with every option on it I could buy.
  #134 (permalink)
Old 12-16-2012, 09:47 AM
mrbill65's Avatar
Originally Posted by sycofrontier View Post
Ok, so I put six quarts back in the tranny, took it for a test drive. I had one hard shift when accelerating really fast, around 5.5K RPM. I sure hope it isn't leaking on the driveway in the morning...
I am in a similar situation as you were, My truck has 108k miles and the transmission has not been serviced. I was wondering if you have developed any problems with your transmission since you did your drain and fill. I was wondering how many miles you have put on since you serviced your transmission.
Thanks
MrBill65
  #135 (permalink)
Old 04-01-2013, 12:51 PM
Atemi's Avatar
Alright guys here's a question i'm sure i've overlooked in these 14 pages. My frontier has close to 110k miles on it, and I doubt the fluids besides oil was changed by the prior owner. What fluid would we suggest to help with such an abuse? J-Matic is the standard, with S-Matic as the synthetic I'm leaning with the synthetic being better. Anyone have a good brand on to go with not to break the bank, as well as any suggestions on what else I should be looking to change soon, or now? Oil i'm running Royal Purple, that I changed myself, got a deal with $5 per bottle.
2007 King LE, 8000k, Injen CAI, Bullydog Performance, Plastidip rims, dual 12 Bandpass sub, Kenwood 650 amp
  #136 (permalink)
Old 04-01-2013, 01:28 PM
Amsoil ATF should work.
  #137 (permalink)
Old 04-01-2013, 01:34 PM
Atemi's Avatar
Then that's what but shall use. Thanks
  #138 (permalink)
Old 04-01-2013, 02:07 PM
You're welcome.
  #139 (permalink)
Old 04-01-2013, 03:35 PM
jlg2002's Avatar
And perhaps a cheaper alternative is Castrol Import ATF if the Amsoil is too pricey. I now have 227,000 on my 05 truck and have been using it since the first flush.
JLG2002
  #140 (permalink)
Old 04-01-2013, 03:48 PM
It's only pricey if you can't afford to buy it.
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
