Hitch Plug Relocated to Bumper
I relocated my 7 pin trailer hitch plug on Monday. I used a 2.25 inch hole saw and then cut away some of the plastic guides (that it used to slide onto the original location) so I could squeeze it through the hole. It would probably fit with less modification if I used a 2.5 inch hole saw.
The drill bit size I used for the plug's bolts was 1/4inch. I slid the plug in, made sure it was straight, marked the holes with a sharpie, used a punch to make a little divot, took the plug out then drilled the two holes. Here are the pics. ![]() ![]() ![]() ![]() NEW PICS: This is a pic of the clip/ cable tie I had to cut so the plug could reach easier. (I tried removing the whole cable tie clip, but I couldn't get the tab through the hole) ![]() Here are the remnants of the plate that held the plug. The sawzall was pretty long so this was a pain for me to cut, I had to hold the sawzall at an angle. I then sprayed the bare metal with some paint. ![]() Here on the side of the plug you can see where I cut the plastic with diagonal cutters. It's not the cleanest job in the world, but it's behind the bumper so who cares. ![]()
| The Following User Says Thank You to EB_05_NISMO For This Useful Post: | ||
ToddG (10-11-2008) | ||
looks great
Nissan should have done it that way originally.
2008 Nissan Frontier LE Crew Cab Long Bed 4X4 in Radiant Silver 2007 Nissan Pathfinder SE 4X4 in Desert Stone |
Good info on the steps taken. Might actually do that today.
OK, did it this morning/afternoon. Turned out fantastic. Anyone thinking about doing this DO NOT I repeat DO NOT use a 2 1/2" hole saw to cut it. I used a 2 3/8 to cut it and had a fun time positioning it to cover the scratches form the hole saw walking a bit, mainly because my barb came loose in the middle of starting it. I really think a 2 1/2" will be too big to cover with the plate.
-Jason Exterior: TruxPort Cover, Chrome Door Handle and Mirror Covers, Billet Grille, ICI Nerf Bars, 2" PRG Mini Lift, Redline Tuning Hood Lift Struts, 20" Ultra 248 Series w/ 275/55/20 Nitto TerraGrapplers Performance: Airaid Quick Fit Intake, Poweraid TBS 2007 Yamaha Wolverine 450 4x4 - K&N Filter, AMR Monster Coil, Power Now, Cycra M2 Handgaurds, Extreme Recovery 2500X Winch, HMF Sport Slip-On, Dune Gear 1.5" Wheel Spacers, Dynojet Kit Last edited by jaf06se : 05-02-2008 at 12:04 AM. Reason: Automerged Doublepost |
great write up thanks! i used a 2 1/8 inch hole saw which made it snug but popped in w/ a little force. i had to grind down the extra plastic to make it flush w/ the bumper. note: you have to disassemble the entire unit to make it work. i just used a small flat head screw driver to undo the clips.
Trailer Parts Superstore - Flat 4-Prong Vehicle Knockout Adapter #47605 or this which would have to be spliced in Trailer Parts Superstore - Flat 4-Prong Vehicle Knockout Connector #48065
jerryp58 (05-15-2008) | ||
Thanks for figuring what size hole saws to use - it helped save me some time!
Instead of cutting off the plate with a saw, I opted for an angle grinder. There is weld the width of the plate on the forward side and a small spot weld on the aft side. I had to use a rotary tool to get to the spot weld since it's kind of tight and the angle grinder made quick business of the bigger weld. Took the grinding wheel to it all after to and hit it with some BBQ paint I had kicking around. A bit cleaner IMO and you won't have to worry about moisture collecting in that gap where you cut off the plate with the saw. Picasa Web Albums - SnapTee - Hitch |
Nice install. Should have been oem. And GO SOX!!!!!
| Thread Tools | |
| Display Modes | |
