Heater Core Flush - Nissan Frontier Forum
post #1 of 8 (permalink) Old 11-17-2010, 02:19 PM Thread Starter
Heater Core Flush
I just recently put a new motor in my 2001 frontier s/c and the mechanic told me I needed to have my heater core flushed because it's clogged from a previous blown head gasket. The heater barely gets warm. I took it to a shop the other day and the guy said that he couldn't flush the heater core because he said there's nowhere for him on the truck to flush...or somethin like that. So what do I do/should I do now? Anybody else have this prob/solution?
lonzorizo is offline
post #2 of 8 (permalink) Old 11-17-2010, 02:33 PM
colin123's Avatar
Feedback Score: 5 reviews
pull the heater core out of the truck and run some decent pressured water through it reverse from normal flow
07 Red Alert Frontier SE KC Auto: Nismo CAI, Custom 3in exhaust w/ flowmaster and 4in Silverline tip (3in from the y all the way back), BFG Rugged Trails, Python 990 Alarm w/ remote start and 1 mile range, ABS Bypass Switch, Front facing child seat.
08 Red Alert Xterra SE Auto: Stock
2011 Sentra SE-R Spec V 6 speed: Stock
92 240sx 5 speed: Stock for now
colin123 is offline
post #3 of 8 (permalink) Old 11-17-2010, 03:04 PM Thread Starter
how do i pull the heater core out/where is it located in my truck?
post #4 of 8 (permalink) Old 11-17-2010, 03:42 PM
colin123's Avatar
you'd have to check a service manual but it should be somewhere in the dash. i don't know much specifics on the first gens
colin123 is offline
post #5 of 8 (permalink) Old 11-17-2010, 06:07 PM
TwoBills's Avatar
To pull the heater core you'll have to pull the dash and everything under it, down to the structure. It's at least a double weekend job, w/a week of driving w/a wire tied guage cluster. If I pulled mine again I wouldn't replace it w/anything but a new unit. Massive hassle. Go to radiatorbarn.com. I'm happy w/the radiator I bought from them.
TwoBills is offline
post #6 of 8 (permalink) Old 11-18-2010, 11:37 PM Thread Starter
can't i flush it by running water or air through the pipes going into the heater core?
post #7 of 8 (permalink) Old 11-19-2010, 05:40 PM
The two coolant hoses running into the firewall go to the heater core. The usual process is to drain the coolant, disconnect them and run water backwards through the heater core, blowing the material clogging the core out (hopefully). I'm not farmiliar with the 01's so I coudn't tell you which is the normal inlet or outlet hose.
bbhzx12 is offline
post #8 of 8 (permalink) Old 11-19-2010, 07:37 PM
TwoBills's Avatar
You could try that but I'd be worried I'd just make matters worse. Especially w/air. The lines are a bear to get off, also.
TwoBills is offline
