Flush vs. Drain/Fill - Nissan Frontier Forum
 2Likes
post #1 of 39 (permalink) Old 04-15-2010, 10:30 AM Thread Starter
I have searched but haven't quite found the answer I am looking for.
It is my understanding that doing a flush on an vehicle with high mileage is not recommended.
However, I have a 07 SE CC w/36k I just grabbed and I have no clue as to what the maintenance history is. The dealer changed the oil and "inspected and certified" it but nothing else (tranny, front/rear diff) wasn't done by the dealer. As a good measure on sanity and great feed from the forum, I am replacing all fluids with Amsoil.
My first question is, do I do a full flush or just multiple drain and fills as some have suggested?
Second, if doing the full flush (14qts?), do I drop the transmission pan and replace the filter as well?
Lastly, is it recommended to add an additive to the tranny? The Auto shop I would have do the full flush, highly recommended a BG additive in addition to the Amsoil. Not sure about that as I have not read anything on here about that as well as the owners manual.
All advise is greatly appreciated.
Thanks in advance.
Bryan
davisbry20 is offline
post #2 of 39 (permalink) Old 04-15-2010, 12:14 PM Thread Starter
wrong section?
did I post this in the wrong section? Do I need to upgrade in order to post this in the appropriate section or get a response?
Mods any suggestions?
post #3 of 39 (permalink) Old 04-15-2010, 12:34 PM
JohninNJ's Avatar
Just my 2 cents...
I will never do a Flush, new or used. After speaking to mechanic friends/reading & being screwed from GM after spending almost 70,000 on a truck, always dealer serviced and just 800 miles out of warranty did the dealer suggest a trans flush and 1 day after that the trans died...NO help from GM for the cost.
JohninNJ is offline
The Following User Says Thank You to JohninNJ For This Useful Post:
davisbry20 (04-15-2010)
post #4 of 39 (permalink) Old 04-15-2010, 12:59 PM
FitzIngarage's Avatar
Quoted: 92 Post(s)
X2
I've never paid to have flushes done on any vehicle we've owned and have gotten over 230,000 Miles on all of them. If fluids are changed per the schedule, I think flushes are a waste of money. With only 36,000 Miles on your "new" '07, simply changing the fluids and filters should suffice. I can't address your automatic tranny query, as I've never owned one. Good luck to you and enjoy your ride!
FitzIngarage is offline
The Following User Says Thank You to FitzIngarage For This Useful Post:
post #5 of 39 (permalink) Old 04-15-2010, 01:10 PM
Mylt1's Avatar
Quoted: 2 Post(s)
no "additive" needed. there just trying to make more money off you. i would, disconnect the trans lines from the cooler and drain out 4-5 qts, fill the trans, drain again, 3-4qts, fill, drain again 3-4 qts, fill. do that till the fluid being pumped out is nice and red as it should be and your GTG. no filter to replace on the trans.
05 LE CC 4X4. SUPER BLACK
Mylt1 is offline
The Following User Says Thank You to Mylt1 For This Useful Post:
post #6 of 39 (permalink) Old 04-15-2010, 01:20 PM Thread Starter
thanks guys for the advise.
Drain and fill it is. I understand this process from all of the write-ups.
What about dropping the pan and replacing the filter. How does this work in conjunction with the drain and fill? I feel like I should change the filter as well?
post #7 of 39 (permalink) Old 04-15-2010, 01:28 PM
JohninNJ's Avatar
Me, I change filters, as for this truck I haven't had it long enough to do it as of yet but I will when the time comes.
JohninNJ is offline
post #8 of 39 (permalink) Old 04-15-2010, 01:29 PM
There is no filter, there is a mesh screen that can be cleaned and reinstalled or replaced. But from what I gather, most people are leaving them be.
Maybe clean it out every few drain and fills? That's my plan anyway...
basik is offline
The Following User Says Thank You to basik For This Useful Post:
post #9 of 39 (permalink) Old 04-15-2010, 02:40 PM Thread Starter
"no filter" ugh! I just ordered one last night from Amsoil. I thought that there was an internal filter, not just the screen. i guess i will have to see if Amsoil will take it back. Or if it's just a replacment for the actual screen, maybe I will just put it in anyway.
Thanks guys for the advice.
Oh...is there a write-up with pics on how to hook up everything for the D/F process mentioned above?
post #10 of 39 (permalink) Old 04-15-2010, 03:35 PM
VoodooSaint's Avatar
Feedback Score: 3 reviews
Grabbed a service reccomendation shreadsheet from a local dealership while I was getting it serviced the other day these are their flushing reccomendations (in kilometres):
Oil Change & Inspection 6000k
Oil Desludge/Engine flush 24 000k
Brake service 30 000 K
Brake Flush 54 000K
Coolant Conditioner 24 000 K
Coolant Flush 48 000 K
Power Steering Flush 54 000 K
Transmission Flush 48 000 K
4x4 Service 54 000 K
2006 Nissan Frontier CC LE 4x4
Goodyear Duratrac/Yokohama Iceguard IG51V, Bilstein height adjustable front shocks, Radflo 2.0 rear shocks, Total Chaos Fabrication upper arms, AC adjustable shackles, OME leaf pack
Volant intake with Amsoil filter and prefilter, Superchipped, Banks Monster exhaust, DBA 4000 slotted front rotors, Stoptech Cryogenic slotted rotors, Hawk brake pads
Leer cap w/ Thule, SoloFabWorks sliders, XOSKEL lightbar w/ KC Daylighters
VoodooSaint is offline
