emergency brake adjustment? - Nissan Frontier Forum
 4Likes
post #1 of 14 (permalink) Old 02-22-2011, 09:07 PM Thread Starter
BABYBUSA01's Avatar
i went to the dealer to get my ecm relay recall swapped out and the service tech. said i could use an emergency brake adjustment. so, could anyone give me a quick walk through about it or know of a DIY on a 05'? i did a search and couldn't find anything. thanks!
05' K.C. SE BLACK 6M PIMPED TO PERFECTION!
08' SUZUKI HAYABUSA ORANGE/BLACK
BABYBUSA01 is offline
post #2 of 14 (permalink) Old 02-22-2011, 09:28 PM
applefrk's Avatar
Quoted: 2 Post(s)
assuming you have a Crew cab....(and i think its the same for King)
pop out the cup holders in the center and unscrew the 2 screws holding the t halves of the center console togheter. push your seats forward adn there are 2 screws on both sides sunscrew these too. the back half should lift off exposing the TCM and the handbrake.
use a DEEP socket and start turning to the RIGHT, this should pull the brake closer. adjust as needed and replace everything in reverse order.
stupid easy when you realize how its done. hope this helps
Nismo49 and Nismo49 like this.
its not turbo lag... its foreplay
applefrk is offline
The Following User Says Thank You to applefrk For This Useful Post:
BABYBUSA01 (02-22-2011)
post #3 of 14 (permalink) Old 02-22-2011, 09:33 PM Thread Starter
BABYBUSA01's Avatar
I really appreciate it!
post #4 of 14 (permalink) Old 02-22-2011, 11:55 PM
Clint's Avatar
Quoted: 361 Post(s)
Isn't there an adjusting nut on the cables under the truck too? There always was in the good old days...
Clint is offline
post #5 of 14 (permalink) Old 02-22-2011, 11:59 PM
applefrk's Avatar
Quoted: 2 Post(s)
you may be right, i never checked for sure but if i remember right there were no bolts under there. it was just a single line clamped to a device that pulled each sides lines. like i said i could be completely wrong.
applefrk is offline
post #6 of 14 (permalink) Old 02-23-2011, 12:09 AM
EB_05_NISMO's Avatar
Quoted: 6 Post(s)
There is another adjustment point at the actual ebrake shoes. Ceck out post #12 in this thread Adjusting Parking brake?
EB_05_NISMO is offline
The Following User Says Thank You to EB_05_NISMO For This Useful Post:
BABYBUSA01 (02-23-2011)
post #7 of 14 (permalink) Old 02-23-2011, 06:35 AM Thread Starter
BABYBUSA01's Avatar
will do, thanks!
post #8 of 14 (permalink) Old 04-27-2011, 03:39 AM
BlueTeg's Avatar
How many clicks do you have to pull up on your e-brake handle for it to engage the brakes enough to prevent the vehicle from rolling down a gradual hill (think of something that you would encounter at shopping center, not a huge hill you'd find in a neighborhood or offroad)?
I looked over the service manual PDF in the DIY section here and it doesn't mention how high up or how many clicks you should hear before the parking brake is "fully engaged" according to factory specs.
Mine takes 12-14 clicks before the brake will engage enough to prevent the truck from rolling (depending on the angle it's parked on). I want to adjust the parking brake but I want to make sure that this is abnormal before doing so.
TIA
06 Nissan Frontier, daily driver and tow rig
94 Civic, time attack / road race toy
BlueTeg is offline
post #9 of 14 (permalink) Old 04-27-2011, 11:46 AM
jjhutton1's Avatar
According to the FSM:
1. Remove rear half of the center console. Refer to IP-10, "Exploded View".
2. Rotate adjusting nut and loosen cable until tension is sufficiently released.
3. Remove the wheel and tire using power tool.
4. Remove the rotor and measure inner diameter at widest point using Tool.
5. Transfer measurement less 0.6 mm to the parking brake shoes and adjust accordingly.
6. Using wheel nuts, secure the disc to the hub to prevent it from tilting.
7. Rotate disc rotor to make sure there is no drag.
8. Adjust cable as follows:
a. Operate parking brake lever 10 or more times with a force of 490 N (50 kg-f, 110 lb-f).
b. Rotate adjusting nut to adjust lever stroke to specification.
c. With parking brake lever completely disengaged, make sure there is no drag on the parking brake.
Lever stroke : 6 − 8 notches [under force of 196 N (20.0 kg-f, 44.1 lb-f)]
2008 SE V6 4X4 CC, Longbed
Axle Vent Mod, WeatherTech Mats, Custom Utili-Track tie-downs, Readylift 2" Spacer/Shackle Lift and much more to come
2004 SC V6 4X4 Kingcab
jjhutton1 is offline
post #10 of 14 (permalink) Old 04-27-2011, 12:35 PM
Avplayer's Avatar
Quoted: 5 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to Avplayer
gotta check mine out this weekend
Avplayer is offline
