Old 09-22-2007, 11:46 AM
DIY fluid change questions ...
DIY auto service is a whole new world to me, so pardon my silly questions:
1. Where is the transfer case located and what does it do?
2. How do I drain and refill the engine coolant?
3. Is the fill plug on the rear diff in the middle of the chamber on the rear side? I thought it would be higher to allow more fluid inside ...
When it's time for these services, is there anything to stop me from doing the diff fluids, transfer case, coolant, ATF, and coolant changes myself?
I'm not afraid -- I'm proficient in carpentry, plumbing, electrical, etc. -- but I'm kind of flying blind as an auto mechanic ...
Thanks!
David
2007 SE V6 4x4 Crew Cab Long Bed, Radiant Silver: SE Value Package, Tow Package, OEM Hood Protector, OEM Fog Lights, Headlight Adjust (1.5 turns), 4 Bed Rope Hooks, 8 Utili-track Cleats & 2 RockyMount Clutch SD, Pathfinder Switch Covers, OEM Rubber Floor Mats, G2 Bakflip, 2" Blind Spot Mirrors, OEM Chrome Handles, EZDown, Street Scene Speed Grill (brushed) ...
Old 09-22-2007, 12:25 PM
HarshReality001's Avatar
the t-case is on the back of your transmission. it directs power to the front differential/wheels. it's basically what engages your 4wheel drive. if you look under the truck, you can follow the front differential backwards.
front diff --> front driveshaft --> transfer case.
you will see it connect the the transmission back there. here is a good write up for changing the fluids (engine oil, front and rear differentials) from thenewx.org. don't worry-all the components are the same. i didnt see a write-up for the t-case, but it is the same. drain and fill.
http://www.thenewx.org/phpbb2/viewtopic.php?t=4320
and here are your recommended fluids/capacities for the change:
Engine Oil:
Type: 5W-30 Oil with API Certification
Capacity: 5 3/8 qt or 5.1 L
Cooling System:
Type: Genuine Nissan Long Lift Anti-freeze or equivalent
Capacity: 2 3/4 gal or 10.2L
Automatic Transmission:
Type: Genuine Nissan Matic J ATF
Capacity: 10 7/8 qt or 10.3L
Manual Transmission:
Type: Genuine Nissan Manual Transmission Fluid HQ Multi 75W-85 or API GL-4, Viscosity SAW 75W-85 or 75W-90
2WD Capacity: 4 1/4 qt or 3.98 L
4WD Capacity: 4 3/8 qt or 4.18 L
Rear Diff:
C200
Type: API GL-5 Synthetic 75W-90 Gear Oil or Equivalent
Capacity: 3 3/8 pt or 1.6L
M226
Type: API GL-5 Synthetic 75W-140 Gear Oil or Equivalent
Capacity: 4 1/4 pt or 2.01L
Transfer Case:
Type: Genuine Nissan Matic D ATF or DEXRON III or MERCON or equivalent
Capacity: 2 1/8 qt or 2.0L
Front Diff:
Type: API GL-5 SAE 80W-90 Gear Oil or Equivalent
Capacity: 1 3/4 pt or .85L
there's nothing stopping you from changing those fluids yourself if you feel capable.
Comment on my upcoming trip -->
X-Country Road Trip!
CarDomain / Gallery / LINXC
Old 09-30-2007, 10:53 AM
GAFronty's Avatar
does anyone have the torque setting for the filler and drain plugs? I've looked through the treads and online shop manuals but cant seem to find them.
Thanks!
GA Fronty
Radiant Silver
'05 SE CC
6 Speed 2WD
Old 09-30-2007, 11:44 AM
For the Fronty plugs go 25 ft-lbs all around and you'll be fine.
Old 09-30-2007, 11:45 AM
http://www.thenewx.org/phpbb2/viewtopic.php?t=2445
Maintenance:
Engine Oil Drain Plug: 25 ft-lbs (Replace Crush Washer)
Transfer Case Fill Plug: 26 ft-lbs (Replace Gasket)
Transfer Case Drain Plug: 26 ft-lbs (Replace Gasket)
Front Differential Fill Plug: 25 ft-lbs (Replace Gasket)
Front Differential Drain Plug: 25 ft-lbs (Replace Gasket)
Rear Differential Fill Plug (C200): 36 ft-lbs (Apply Silicon RTV or Equal)
Rear Differential Drain Plug (C200): 36 ft-lbs (Replace Gasket)
Rear Differential Fill Plug (M226) (with or without Locker): 25 ft-lbs (Apply Silicon RTV or Equal)
Rear Differential Drain Plug (M226) (with or without Locker): 20 ft-lbs (Apply Silicon RTV or Equal)
Manual Transmission Fill Plug: 25 ft-lbs (Replace Gasket)
Manual Transmission Drain Plug: 25 ft-lbs (Replace Gasket)
Automatic Transmission Drain Plug: 25 ft-lbs (Replace Gasket) (both 2wd and 4wd models)
Old 09-30-2007, 02:30 PM
GAFronty's Avatar
thanks for the info! and for those who didn't know, the drain and filler plugs take a 10mm hex head to remove.
GA Fronty
Radiant Silver
'05 SE CC
6 Speed 2WD
Old 09-30-2007, 10:12 PM
Eric05mx's Avatar
What rear diff. do we have? C200 or M226
05 Nismo KC 6-speed
BFG A/T's
Nismo Intake
Old 09-30-2007, 10:42 PM
RedAlert's Avatar
You jave a nismo M226 aka "dana 44"(not a true one)
Old 09-30-2007, 10:45 PM
Which trucks have C200 vs. M226?
I think the C200 has the 14mm hex fill plug, right? (Drain is 10mm, BTW)
Old 09-30-2007, 10:49 PM
Eric05mx's Avatar
Ok, thanks
05 Nismo KC 6-speed
BFG A/T's
Nismo Intake
