Diagnose / correct speedometer not working - Nissan Frontier Forum
post #1 of 13 (permalink) Old 07-08-2008, 03:32 PM Thread Starter
Hi,
My son has a 99 Frontier 4wd 6cyl Auto. The speedometer quit working (also the check engine light came on at the same time). How do we diagnose the problem so that we don't buy the wrong expensive parts? How we then make the repairs?
Thanks, JenCliff
jencliff is offline
post #2 of 13 (permalink) Old 07-08-2008, 04:15 PM
pidge's Avatar
Quoted: 5 Post(s)
pretty sure in the states you can have a "check engine" light read for free. I'm sure someone will chime in to back me up on this. Also my old 96 hardbody had the same problem and I recall some frontiers as well. I ripped my cluster apart to have a look at it, but couldnt find anything out of place, I was told I had to replace my whole gauge cluster to fix the problem. I never bothered, I just kept erasing the code once a week.
pidge is offline
post #3 of 13 (permalink) Old 07-08-2008, 04:20 PM Thread Starter
Check engine light staying on not the problem. Without the speedo, there is a real ticket problem - and I think the cruise doesn't work either. No way to stay below the radar, so we need to fix it.
jencliff is offline
post #4 of 13 (permalink) Old 07-08-2008, 04:47 PM
GPS could help control the speed.
Sounds like a Vehicle Sped Sensor. I would try autozone and see if they can pull the code for you and help narrow it down.
Cheers--Derek
2bigtanks is offline
post #5 of 13 (permalink) Old 07-09-2008, 06:47 AM
06nismoKC's Avatar
Cheers--Derek
I agree with Derek on this one with the speed sensor and excellent advice on having the code checked first.
06 nismo, White, Stock mostly, retrax Pro bed cover custom pipe rack. I thought I had purchased JUST what I wanted...UNTIL I CAME TO CLUBFRONTIER.
06nismoKC is offline
post #6 of 13 (permalink) Old 07-09-2008, 06:36 PM Thread Starter
I sent my daughter with the car. This is what she said the Auto Zone guy told her
"I went to Auto zone and they tested it and said it could one of two different sensors. the code is a "knock warning" apparently from cheap gas. any how he said it depends on the oem code on the sensor when it's pulled, it's either oem #25020-85po2 ($144.99) or oem #25010-74po1 ($63.99)."
She seemed to think this was two different versions of the Vehicle Speed Sensor from what he said.
Is this any help?
jencliff is offline
post #7 of 13 (permalink) Old 07-09-2008, 06:51 PM
Senior Moderator
igbar's Avatar
Quoted: 3 Post(s)
Do you know which code it was?
Link to post with code #s and their meaning.
1st Gen FAQ...PLEASE READ. ADD INPUT
NEW MEMBERS MUST post in the New Member Intro forum first to unlock their account.
igbar is offline
post #8 of 13 (permalink) Old 07-09-2008, 08:44 PM
Mandangalo's Avatar
Quoted: 5 Post(s)
may not be related at all......but the CEL is sometimes kicked on from the speedo not hooking up. i had a friend that disconnected his speedo so the odometer would not log miles travelled.
well it gave him a CEL and he was told that happened cause of the disconnect. some ecus, from what i was told, regulate fuel/air mixture through vehicle speed.
not sure if that helps or hurts your cause. good luck
Mandangalo is offline
post #9 of 13 (permalink) Old 07-11-2008, 11:24 AM Thread Starter
I sent her back. They said that P0500 & P0325 come up.
Hope this helps.
Thanks, Jencliff
jencliff is offline
post #10 of 13 (permalink) Old 07-11-2008, 11:36 AM
Senior Moderator
igbar's Avatar
Quoted: 3 Post(s)
I know this doesn't help you with which PN to buy from AutoZone, but it's something. I hope somebody else can chime in who has had this problem before.
These are the codes for the 3.3 and 2.4 frontier and exterra
Nissan Frontier Extera Truck 3.3L OBDII Trouble Codes DTC Troubleshooting
FRONTIER & XTERRA 3.3L
P0000
No Self Diagnostic Failure Indicated
P0100
MAF Sensor
P0105
Absolute Pressure Sensor
P0110
IAT Sensor
P0115
ECT Sensor
P0120
TP Sensor
P0125
ECT Sensor
P0130–P0134
Front HO2S RH Bank
P0135
Front HO2S Heater RH Bank
P0136–P0140
Rear HO2S RH Bank
P0141
Rear HO2S Heater RH Bank
P0150–P0154
Front HO2S LH Bank
P0155
Front HO2S Heater LH Bank
P0157–P0161
Rear HO2S LH Bank
P0171
Fuel Injection System Lean RH Bank
P0172
Fuel Injection System Rich RH Bank
P0174
Fuel Injection System Lean LH Bank
P0175
Fuel Injection System Rich LH Bank
P0180
Tank Fuel Temperature Sensor
P0217
Engine Over Temp
P0300
Multiple Cylinder Misfire
P0301–P0306
Misfire Cylinders 1–6
P0325
Knock Sensor
P0335
CKP Sensor
P0340
CMP Sensor
P0400
EGR Function
P0402
EGRC-BPT Valve Function
P0420
TWC Function
P0430
TWC Function
P0440
EVAP System Small Leak
P0443
EVAP Canister Purge Control Valve & Solenoid Valve
P0446
EVAP Canister Vent Control
P0450
EVAP System Pressure Sensor
P0500
VSS
P0505
IAC-AAC Valve
P0510
CTP Switch
P0600
A/T Control & Communication Line
P0705
Park Neutral Position Switch/Circuit
P0710
ATF Temp Sensor/Circuit
P0720
Vehicle Speed Sensor/Circuit
P0725
Engine Speed Signal
P0731
A/T 1ST Gear Function
P0732
A/T 2ND Gear Function
P0733
A/T 3RD Gear Function
P0734
A/T 4TH Gear Function
P0740
TCC Solenoid/Circuit
P0744
A/T TCC Switch/Valve Function
P0745
Low Pressure Solenoid/Circuit
P0750
Shift Solenoid A/Circuit
P0755
Shift Solenoid B/Circuit
P1105
MAP/BARO Switch Solenoid Valve
P1148
Closed Loop B1
P1168
Closed Loop B2
P1320
Ignition Signal
P1336
CKP Sensor
P1400
EGR Valve & EVAP Canister Purge Control Solenoid Valve
P1401
EGR Temperature Sensor
P1402
EGR System
P1440
P1444
Purge Volume Control Valve
P1446
EVAP Canister Vent Control Valve
P1447
EVAP System Purge Flow Monitoring
P1448
Vacuum Cut Valve
P1490
Vacuum Cut Valve Bypass Valve
P1491
P1605
A/T Diagnosis Communication Line
P1705
Throttle Position Sensor/Circuit A/T
P1706
PNP Switch/Circuit
P1760
Over/Run Clutch Solenoid/Circuit
igbar is offline
