What do you mean by master key? there are just regular/immobilizer keys and valet keys.
I have seen the bcm fail after trying to reprogram keys, all your other issues will be related. I would suggest unplugging/disconnecting the bcm (under driver side dash, black box with 3 connectors) for 10-15 mins and see what happens. Sometimes it will fix itself, although it will only be temporary.
Keep in mind, if you replace you're bcm, it must be programmed/configured to your vehicle.
2011 FRONTIER SV 4X4 6SPD CC/LB Knight Armour
Lifted, truetrac, injen, ims, bullydog, skids, HID projectors, WRP underdrive crank pulley, blah, blah blah
