Automatic transmission radiator oil cooler bypass - Page 11 - Nissan Frontier Forum
 1Likes
post #101 of 659 (permalink) Old 01-11-2010, 12:36 PM
penski61's Avatar
Originally Posted by colin123 View Post
yeah i probably wouldn't do this in most areas without a cooler with a fan on it. i'm sure on a 90* day the tranny would get pretty hot.
when we moved in october , it was about 70 at night and i was towing a trailer , fan was cyling alot as well then too
i didnt realize how much heat build up when towing
02 sas'd 1st gen
07 sas'd 2nd gen
02 chevy reg cab with 8.1
penski61 is offline
post #102 of 659 (permalink) Old 01-11-2010, 01:37 PM
colin123's Avatar
Feedback Score: 5 reviews
i plan on doing the bypass and doing a cooler with a tstat and fan but i'll probably put in a tranny temp probe and gauge first and monitor the temps and how fast it heats up and what normal temps are and stuff so i can compare when i do the bypass how everything differs.
07 Red Alert Frontier SE KC Auto: Nismo CAI, Custom 3in exhaust w/ flowmaster and 4in Silverline tip (3in from the y all the way back), BFG Rugged Trails, Python 990 Alarm w/ remote start and 1 mile range, ABS Bypass Switch, Front facing child seat.
08 Red Alert Xterra SE Auto: Stock
2011 Sentra SE-R Spec V 6 speed: Stock
92 240sx 5 speed: Stock for now
colin123 is offline
post #103 of 659 (permalink) Old 01-16-2010, 11:03 PM
Just picked up an 08 CC SE. Reading on here, I'm planning on doing the bypass. My question is, do all auto Frontiers have the aux cooler for the transmission? I'm sure mine does, but just looking down in front of the radiator, I'm only seeing the a large cooler in front of the radiator on the passenger side. To me it looks more like an AC condenser just because of the size, but I've been wrong many times before.
Just wanted to ask before I pull the skid plate and do the bypass.
Eury is offline
post #104 of 659 (permalink) Old 01-17-2010, 01:26 AM
colin123's Avatar
the larger cooler passenger side infront of the radiator, you can get b&m coolers with fans and t stats pretty much the exact same size to use there instead of this factory one.
colin123 is offline
post #105 of 659 (permalink) Old 01-17-2010, 08:11 AM Thread Starter
Zero Six LE's Avatar
Quoted: 877 Post(s)
The AC condenser is in front of the radiator. The transmission oil cooler is in front of the AC condenser.
Zero Six LE is offline
post #106 of 659 (permalink) Old 01-26-2010, 06:16 PM
Quoted: 11 Post(s)
If you want to do this with zero mess and waste, do it cold. It was about 20°F out and the truck had been sitting for a couple of days, stone cold. Almost nothing spilled out -- maybe a drop or two. I was expecting a gusher and had my drain pan waiting, but nothing spilled out. Also, I was expecting the hoses to be brittle due to the cold, but they were pliable and came off with no drama.
2WD_NISMO is offline
The Following User Says Thank You to 2WD_NISMO For This Useful Post:
Zero Six LE (01-26-2010)
post #107 of 659 (permalink) Old 01-26-2010, 10:03 PM
05XE's Avatar
Quoted: 6 Post(s)
Wondering if I should do this when my 5yr/60k powertrain warranty is up?? I have an 05 and wonder about the coolant/oil problem...
drive to arrive. don't become a statistic.
05XE is offline
post #108 of 659 (permalink) Old 01-27-2010, 12:31 PM
bbyers's Avatar
is there 2 hoses to plug off on the radiator when doing this mod?
i would think there would be an inlet and an outlet for the transmission fluid?
2004 VTX/ 2000 DS 650 / 2011 800 RZR / 2011 170 RZR (kids)/2010 KFX90 (kids)/ 2005 Nissan Frontier Crew Cab 4x4 100,000 miles / XBOX Gamertag Byers101
bbyers is offline
post #109 of 659 (permalink) Old 01-27-2010, 01:20 PM
sirnixalot's Avatar
Quoted: 2 Post(s)
Send a message via MSN to sirnixalot
check the first page and first post and look at the last picture again
2008 Nissan Navara 2.5L TDi
PRG 4wd Advanced lift w' Deavers - DIY 2" body lift
Cusco Catch Can - Custom 3" intake - Custom GT2860 turbo conversion with full 3" exhaust/Magnaflow resonator & 3 chamber XL muffler- Custom 2.25" IC hard piping
DTE PDI chip, Turbotimer, Defi Red Racer boost & EGT gauges
AEM W/I kit 10gph nozzle & 5gal reservoir
ATX Cornice 17x9 w/285/75R17 Powermeter L850 M/T's
EBC Greenstuff 6000 pads, Goodridge lines up front, Earls out back
DIY/Custom tow hitch reciever
http://smg.photobucket.com/albums/v4...ixalot/Navara/
sirnixalot is offline
post #110 of 659 (permalink) Old 01-27-2010, 02:36 PM
bbyers's Avatar
I see said the blind man. all we are doing is joining those two hose before they go into the radiator. Is any kind of extra trans cooler needed after doing this mod?
I wondering if its possible to mount some kind of inline cooler where we make the connection. Instead of using a coupler use a inline cooler. Any thoughts?
bbyers is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
