Fuel Line Replacement Help - Nissan Frontier Forum
post #1 of 7 (permalink) Old 07-09-2011, 06:23 PM Thread Starter
ASCSurveyor's Avatar
So I need to replace the fuel line in my truck that starts under the cab, and goes into the throttle body ***'y. I'm sure there's a technical name for that part, but I haven't figured that out so far. That's probably my main problem.
Anyway, here's a picture of the part that let me down. It sprung a leak about 2 weeks ago, and with help, I was able to patch in a piece of rubber hose so that I could get home from work without the truck exploding. Since then, the truck has sat in the parking lot, waiting for the new part to arrive.
For reference, the part I ordered, and need to replace, is reference number 16440N in the diagram below.
I have the service manual for the truck, and was hoping this would be a quick and easy fix, once I had the part. Remove broken line, install new line, enjoy running vehicle. However when I unwrapped the part, I quickly realized that I wouldn't be able to replace just the problem section, but the entire length of hose from the fuel line underneath the truck, to the TB ***'y.
Looks like I'm going to need some time to do it, and a few tools. Both of which I have. However, I'd like to find the section in the service manual where it describes what all I need to do in removing the line. The end with the quick-connector I get, but the other end by the TB I don't. Not sure how that works, and I need to know before I start working.
I tried looking up every part of the fuel system in the service manual, but the only thing it tells me is how to remove the fuel pump. I don't care about the fuel pump. Or the fuel tank. Or even that section of line. I want to know about the section up by the engine, but can't seem to find any info on it.
Anyone know where I need to look?
2005 Frontier XE KC 4x2
2009 Ducati Sport 1000
ASCSurveyor is offline
post #2 of 7 (permalink) Old 07-09-2011, 07:23 PM
dubie2003's Avatar
Quoted: 10 Post(s)
When you say TB thingy, I assume you mean the fuel rail in which holds the injectors into the head.
You are going to need a special fuel line tool to remove it properly. Others have used plyers and screwdrives but there is a special tool that will eliminate any damage.
I'd imagine that it is an 1hr job at most.
07 SE CC Auto
dubie2003 is offline
post #3 of 7 (permalink) Old 07-09-2011, 09:12 PM Thread Starter
Yes, the fuel rail. Throttle Body Assembly was the best description I could come up with.
I'm kinda keen on using the write tool for the job. Not big on using screwdrivers as hammers and the like.
When you say "1 hour job", do you mean one hour at a shop, or one hour of a home mechanic?
post #4 of 7 (permalink) Old 07-09-2011, 09:24 PM
dubie2003's Avatar
Quoted: 10 Post(s)
Should be 1hr for the average guy with the correct tools.
07 SE CC Auto
post #5 of 7 (permalink) Old 07-10-2011, 12:18 AM Thread Starter
Sounds like it would be a snap for a trained professional to do at the dealer, while I'm getting my state inspection and oil change then.
post #6 of 7 (permalink) Old 07-10-2011, 12:35 AM
dubie2003's Avatar
Quoted: 10 Post(s)
As long as it is a true mechanic doing the job it will be. If they have one of their part time stoners doing the work, you will be screwed and your truck will burn to the ground.
07 SE CC Auto
post #7 of 7 (permalink) Old 07-10-2011, 09:37 AM Thread Starter
I'll just have the dealer do it when I'm in for service then. At the very worst, it sounds like I'll get to watch some fire... which is always entertaining.
  Nissan Frontier Forum > Nissan Frontier Forums > 4 Banger Lounge
