Go Back   Nissan Frontier / Navara Forum > Nissan Frontier Forums > 4 Banger Lounge
Old 06-11-2008, 02:02 PM
Sly Tuna's Avatar
E/f Install!! Ssiiickkk!!!
Well i installed my 16" electric fan a couple of days ago. I pulled my old Fan, and shroud out, then wired the fan to a rocker switch inside my cab. Remembering to turn it on was a pain, so i wired it to my head unit power. Only con to that, is I cant play music, without running my battery down. I had two black steel bars sitting in my back yard, which i cut to fit(radiator support). I mounted the fan onto the 2 bars, then mounted it onto the radiator support, using self tappers, and Nuts and bolts.
I noticed a big difference in performance. I rev A LOT faster. Im only in first gear for a second before i hit 3k rpm's. Not to mention its way easier to spin my tires. My truck also does way better up hills. WAY WORTH IT GUYS! Install took only 3 hours.
06 Nissan Frontier XE KC 5 spd.
Wheels: (Titan 18" 6 spokes)(1.5 spacer/adapters) Rear: (10 leaf deaver leaf pack)(2.25 Sway-a-way Res. shocks)( Front: (Cst 4" spindles)(PRG Heim UCA's)(2.5" Sway-a-way Coil overs 625 LB springs)(NO Sway Bar) (SS Brake Lines) Performance: (WRP Crank Pulley)(Cone Filter on air box)(6 wire grounding kit)(Electric fan)(22" Cherry bomb glass pack muffler) Visual: (painted: Front bumper, grille, door handles, mirrors)(red Calipers) De-Badged)(No Bed liner) Sound: (Pioneer HU)(kenwood amp 500 RMS)(Alpine Type R sub 500RMS)(custom 1.5 Cubic foot carpeted enclosure)(stock speakers)
Old 06-11-2008, 02:13 PM
Devilrunner665's Avatar
Send a message via Yahoo to Devilrunner665
looking good...great job....how about a list of parts used?
I have a stock 07 XE....can't you tell?
*Frontier World Order.....The uprising is upon them.....
Leave Nothing Behind
http://www.youtube.com/Devilrunner665
http://edwin-haroutonian.magix.net/
add yourself to my buddy list here
http://www.myspace.com/devilrunner665
Old 06-11-2008, 02:42 PM
zoomzoom's Avatar
Why don't you use a different wire other than the headunit as the turn on lead? Probably a wire that gets power after the second click of the key. Then radio is no problem since it comes on with the first click of key.
Old 06-11-2008, 03:49 PM
adrenaline503's Avatar
Why dont you hook it to a thermometer so it only comes on when it needs to?
2004 Nissan Frontier Crew Cab
Softopper
Old 06-11-2008, 03:51 PM
06_footy's Avatar
my ? is why do u need a switch and all that and wuts the price?
myspace.com/unawareconception
2006 crewcab SE 2wd
Old 06-11-2008, 04:47 PM
Upgraded's Avatar
Agreed, Flex-a-lite 31147 - Flex-a-lite Adjustable Electric Fan Controllers - summitracing.com
2007 SE CrewCab LongBed
PRG mini lift, Undercover tonnaue
Old 06-11-2008, 04:57 PM
06_footy's Avatar
so with this equipment i wouldnt have to worry about having to switch it right ?
2006 crewcab SE 2wd
Old 06-11-2008, 07:15 PM
IDK if only have the 16" will be enough for those hot days in the desert. What did you do with your aux fan?
The thermometer is going to be better in the long run but the switch might be needed if you are doing any kind of water crossings.
Just make sure you keep an eye on the temp gauge and hopefully it will be alright.
Old 06-11-2008, 07:20 PM
Sly Tuna's Avatar
One electric fan (i used 16")
5' of steel bar
4 1/2"self tappers
4 1" Self tappers
2 1 inch bolts
2 nuts
2 self locking washers
5' 12awg. wiring.
All around $100. Well worth it. And about the thermometer. Id rather have it constantly running to keep my engine cool, and i will however wire it to something that turns on, on the second click. Thanks for the feedback. At the moment i am installin my CST 4" spindles, Adapters. Titan 6 spoke 18"rims, and tires .
Old 06-11-2008, 07:29 PM
Thanks for the info...lifting huh.... that means you'll be going out next time me and black pearl plan something right...
