Go Back   Nissan Frontier / Navara Forum > Nissan Frontier Forums > 4 Banger Lounge
  #21 (permalink)
Old 05-21-2008, 06:53 PM
Devilrunner665's Avatar
Send a message via Yahoo to Devilrunner665
nice intake...
Thats a great looking setup.... i also created my own back in October when i got frustrated with a k&n...but i chose to run a dual intake setup. yes, a dual intake. basically, from the air box, it splits into a Y-connector. one end is going across the compartment much like the original set-up and the other is turn 45 degrees down( had to cut fan shroud for this set-up to fit). the filter that is turned down also has a velocity tunnel directly feeding it cold air. it is receiving a lot of cold air and no engine codes have come up since the install. i do have a make shift tornado on both ends for higher velocity of entrance. i will try to have pics up as soon as possible. amazing sound from the 2 filters with a 40 series flowmaster.
  #22 (permalink)
Old 06-08-2008, 07:04 PM
SuperBlk07's Avatar
mission complete
Originally Posted by canes5time View Post
I actually thought about making a kit and selling it on here and ebay. It works perfect on my truck. I gave a list of materials. If they want to try it they can. If someone lived close enough to me, I would help them if they wanted me to.
For the past few weeks i've been collecting the parts for this kit, and friday i put it all together onto my 07. It is definitley worth the money and really didnt take that long to install. i set it up a smidge different but only so i wouldnt have to cut any wires. ill get some pics up for yall to see. it works excellent and does feel like a sufficient power increase over stock. the sound is also amazing.
  #23 (permalink)
Old 06-13-2008, 10:36 PM
canes5time's Avatar
Talking
Hooray!
Someone finally tried it. Please post some pics.
2006 Frontier XE Red Brawn
Inside: Alpine...CDA-9857...SPR-17LS Front...SPS-17C2 Rear...MRP-F250...PLT-5 Enclosure...Sirius...iPod, Scangaugell w/Blendmount, OEM Maplight/Sunglasses Holder, Xterra Hooks, Autovation Pedals & Heel Guard, Tint
Outside: AVS Bug Shield & Ventvisors, TruXedo LoPro, Debadged Tailgate, Street Scene Roll Pan, OEM Splash Guards, V-Grille, Keyless Entry Key Pad, Tow Hook
Mechanical: Flowmaster 60 Series w/SS Tip, K&N Drop-in Filter, Grounding Kit, Bosch Icons, Dual Electric Fan Mod, Unorthodox Racing Crank Pulley, Custom Hood Prop, EZDown, OEM Fog Lights, PIAA Headlamps, Synthetic Fluids, The worlds 1st XE CAI!
  #24 (permalink)
Old 06-13-2008, 10:39 PM
hey bro, check this out...this is my new set up....ram air intake?!
I have a stock 07 XE....can't you tell?
*Frontier World Order.....The uprising is upon them.....
Leave Nothing Behind
http://www.youtube.com/Devilrunner665
http://edwin-haroutonian.magix.net/
add yourself to my buddy list here
http://www.myspace.com/devilrunner665
  #25 (permalink)
Old 08-29-2008, 07:07 PM
kenyonja's Avatar
Just FYI to anyone that may want to do this intake (from the OP), here is an ebay auction for the MAF assembly: eBay Motors: 03 04 05 06 NISSAN 350Z/G35 AIR FLOW METER/SENSOR (item 140217679393 end time Sep-17-08 14:52:50 PDT) . You may want to ask the seller for a picture to make sure it's the right thing, but this is the cheapest I've found. For a while now I have been cruising ebay to find one of these and finally found one for myself. I finagled an ebay seller into selling me just the plastic tube from one of these MAF assemblies for a reduced price and it's on its way . So here's one for anybody else. Good luck!
'06 Frontier XE, 2.5L Auto, King Cab, 2WD, Silver
Owner since June '08, and freakin' loving this truck!
Best MPG: 25.8
Interior Mods: Battery-powered ambient temp sensor, all weather genuine nissan floor mats
Exterior Mods: Custom grille, splash guards, ventvisors, OEM style aftermarket fog lights (wired using this guide)
Performance mods: CAI , Electric Fan
Future Mods: Stock XE wheels painted black, spray in bedliner, winter cap, Trailer Wiring Harness, Body Side Moulding, Scangauge II, Bug Deflector, Aftermarket Stereo + adding Steering Wheel Controls, cab maglite mount, power inverter
  #26 (permalink)
Old 08-29-2008, 07:27 PM
i am working a custom one-piece pipe for our trucks right now
  #27 (permalink)
Old 08-29-2008, 08:31 PM
Sly Tuna's Avatar
Yay!!!!
06 Nissan Frontier XE KC 5 spd.
Wheels: (Titan 18" 6 spokes)(1.5 spacer/adapters) Rear: (10 leaf deaver leaf pack)(2.25 Sway-a-way Res. shocks)( Front: (Cst 4" spindles)(PRG Heim UCA's)(2.5" Sway-a-way Coil overs 625 LB springs)(NO Sway Bar) (SS Brake Lines) Performance: (WRP Crank Pulley)(Cone Filter on air box)(6 wire grounding kit)(Electric fan)(22" Cherry bomb glass pack muffler) Visual: (painted: Front bumper, grille, door handles, mirrors)(red Calipers) De-Badged)(No Bed liner) Sound: (Pioneer HU)(kenwood amp 500 RMS)(Alpine Type R sub 500RMS)(custom 1.5 Cubic foot carpeted enclosure)(stock speakers)
  #28 (permalink)
Old 09-17-2008, 07:02 PM
kenyonja's Avatar
I finally got all the parts together for the canes5time's setup. I emailed an ebayer and convinced him to sell me the plastic tube that holds the MAF sensor instead of the whole assembly for half the price (got it for $40 + shipping). I did have to extend the MAF wires about 10-12", which was easy but I would have preferred not to have to. Oh well.
Pics!:
One thing I would like to add about the small tube coming off of the original intake hose is that, if you use the vacuum adapter plastic tube that the OP specified (which I did) you will need a 3/4" hose as an adapter. I don't think I explained that very well, so anybody let me know if you want a better explanation.
It has a REALLY COOL sound when revved now. I hope that I keep my foot out of the gas enough to get the small mileage increase I'm looking for from it, HAHA.
Best MPG: 25.8
  #29 (permalink)
Old 09-17-2008, 07:47 PM
Tx. Frontier's Avatar
looks just like the original by canes..w/ all these guys putting together their own intakes, it makes me want to make one as well.
2006 Black + White 5-Speed XE (4-cyl)
-Stock Rims(black), BFGoodrich 33x10.50 r15 A/T's, 3" PRG Front Spacers, 4" CST Spindles, Energy Suspension 11/16" UCA Bumpstops, Bilstein 5125 Series Rear Shocks, 3" Fabtech Blocks, 1.5" Calmini Shackles, Black Headlights, 5000k Hyper Yellow Halogens, Bedlined "V" Grill, White Honeycomb Grill, Blacked-Out Rear Bumper, Chopped-off Front Bumper, 1.5" Ezaccesory Wheel Adapters, Memphis Audio 16-PR100.2 Amp, (Cheap) 12" Profile Baja Subwoofer
-Saving up for more mods: ucas, radflos, front bumper
  #30 (permalink)
Old 09-17-2008, 07:54 PM
dont make start a thread called "patience is virtue" after i just wrote "impatience is virtue"
