what size winch? - Nissan Frontier Forum
post #1 of 22 (permalink) Old 09-25-2006, 10:52 AM Thread Starter
Redcrew's Avatar
Quoted: 9 Post(s)
what size winch?
How do you determine what size winch to get? I know the bigger the better but what would be the minimum? Do you go on rolling capacity or dead weight? There’s just to many things to consider.
05 Black Nismo
Redcrew is offline
post #2 of 22 (permalink) Old 09-25-2006, 10:56 AM
stevet47's Avatar
Feedback Score: 3 reviews
The general rule of thumb is 1.5times the GWV of the heaviest vehicle you plan of winching.
stevet47 is offline
post #3 of 22 (permalink) Old 09-25-2006, 11:19 AM
Panman06's Avatar
Also, be aware that a 9000lbs winch will only pull the full 9000lbs on the first layer of cable. As more cable is wound around the drum, the capacity decreases.
'06 SE Crew 4WD 6MT -KIA 12/2009
2010 Nissan Titan Pro4X Navy Blue
Panman06 is offline
post #4 of 22 (permalink) Old 09-26-2006, 04:04 PM Thread Starter
Redcrew's Avatar
Quoted: 9 Post(s)
Ok so the truck gwv is 5600 so i should get a 9k lb winch? Just sounds like alot to get me unstuck. would'nt somthing having Up to 6000 lbs. pulling capacity for rolling stock work? I dont wheel much so I really dont want to spend big cash. I was looking to get the front hitch and mabe one of the portable winches so that I dont have to have it on the truck all the time.
05 Black Nismo
Redcrew is offline
post #5 of 22 (permalink) Old 09-26-2006, 04:14 PM
Webwheeler Extraordinaire
07Frontier's Avatar
You have to take resistance into account. Slope, terrain, etc all add to the amount of force it will take to get you unstuck (hence the 1.5 GWV rule). Trust me when I say you will regret going cheap on a winch if/when it doesn't free you from whatever obstacle has ahold of you. Of course, you could get a snatchblock or two to multiple the pulling force and go with a smaller winch but that is your choice. The multimount is a good option as it allows you to free yourself forwards or backwards but it won't help if you do not have enough winch to get you out. Just my .02.
Taken from http://www.pirate4x4.com/tech/billavista/Recovery/
More importantly, the "effective weight" of a "stuck" 4x4 is very often FAR more than 1.5 times the GVW. The following data on how to more accurately estimate the "effective weight", is taken from the world of professional heavy recovery - the guys that recover Tractor-trailers that have flipped on their side for instance, as well as U.S., Canadian, and UK Military recovery manuals.
Once you have accurately estimated or measured the trucks loaded weight (LW) you can calculate the resistance to be overcome in any recovery situation (this is commonly known as the ROLLING resistance). There are 4 types of resistance that must be accounted for to accurately assess the resistance that must be overcome. These are surface resistance, damage resistance, mire (stuck) resistance and grade (slope) resistance. Calculate them all as follows:
Surface resistance
A pull of 1/10 LW will cause a free wheeling truck to move on a hard, level surface.
A pull of 1/3 LW will cause a free wheeling truck to move on a softer surface, such as grass or gravel,
Damage resistance:
A pull of 2/3 LW will be required to move if the wheels cannot rotate (as if the brakes were fully applied), the pull required to overcome the resistance (drag) the truck id 2/3 or 67% of the LW. Damage resistance includes surface resistance (i.e. you only use one or the other)
Stuck (mire) resistance:
A pull of 100% of LW will be required if the truck is stuck to a depth of the sidewall on the tires.
A pull of 200% of LW will be required if the truck is stuck to the hubs.
A pull of 300% of LW will be required if the truck is stuck to the frame..
Mire resistance includes damage resistance (i.e. you only use one or the other)
Grade (slope) resistance:
Upgrade (vehicle has to be recovered up a slope or grade)
15 degrees - add 25% of LW
30 degrees - add 50% of LW
45 degrees - add 75% of LW
Vehicle recovery on level ground - no correction
Downgrade (vehicle has to be recovered down a slope or grade)
15 degrees - subtract 25% of LW
30 degrees - subtract 50% of LW
45 degrees - subtract 75% of LW
07Frontier is offline
post #6 of 22 (permalink) Old 09-26-2006, 05:03 PM
Panman06's Avatar
Good point. I forgot about multiple snatch blocks. I'm planning on a Ramsey 9500lbs with four snatch blocks.
Panman06 is offline
post #7 of 22 (permalink) Old 09-26-2006, 05:23 PM Thread Starter
Redcrew's Avatar
Quoted: 9 Post(s)
Great info! Thanks. I think I'll probably go with a 9k and carry snatch blocks too, But being only 2wd I'm not going anywhere that will ever get me stuck to the frame.
05 Black Nismo
Redcrew is offline
post #8 of 22 (permalink) Old 09-27-2006, 09:18 AM
07Frontier's Avatar
You say that now but let's see what you say after you put that winch on and start to feel brave.
post #9 of 22 (permalink) Old 09-27-2006, 03:20 PM
nismogone's Avatar
have yall looked at the summit brand winches. they are made by t-max which is the fastest electic winch on the market. even faster than a warn but you can get am integrated 10,000lb for $655. also comes with wireless controls.
http://store.summitracing.com/egnsea...=KeywordSearch
dad leave my signature alone
nismogone is offline
post #10 of 22 (permalink) Old 09-27-2006, 03:50 PM Thread Starter
Redcrew's Avatar
Quoted: 9 Post(s)
My wife says I'm not permitted any bravery.
05 Black Nismo
Redcrew is offline
  Nissan Frontier Forum > Nissan Frontier Forums > OffRoad / 4x4
