Rear end options on '05 SE - Nissan Frontier / Navara Forum
Go Back   Nissan Frontier / Navara Forum > Nissan Frontier Forums > OffRoad / 4x4
Old 09-29-2007, 09:14 PM
CoastalDefender's Avatar
The title pretty much says it all. I have a 2005 CC SE and would like something else in the back end.
What options are out there?
this looks good if it will fit my rig-
http://www.4x4parts.com/public_html/...649ca8da01259d
Will it fit? What other options do I have if it won't?
Also, if I want something in front, am I going to HAVE to do an SAS, or are there other options for me out there?
2005 Frontier CC SE, PRG 2" Front Spacers, AC AAL 3" Rear Springs, Rancho RS5000 Shocks, 265/75R16 Dean Mud Terrain, ARE Cap, Yakima Racks (Cab and Canopy), KMA Multicarrier, AT Fuel Can Carrier, Scepter Fuel Can, Scepter Donkey Dick, 48" Hi-Lift.
Old 09-29-2007, 09:26 PM
EB_05_NISMO's Avatar
As of this time I do not believe there are any aftermarket options for those without a nismo. The only thing you could do would be to swap in a nismo rear end.
ClubFrontier Rules and Guidelines
2005+ Frontier Information (FAQ)
Nissan does not care about it's customers or quality after your standard warranty is up. You should strongly consider this if you plan on purchasing a Nissan.
Old 09-29-2007, 09:41 PM
05se's Avatar
If you truck is a 6speed 4x, I think ARB make a locker for the rear?
SHOW TRUCKS SUCK !!!!!
Old 09-29-2007, 10:30 PM
Mainerunr's Avatar
not yet but it's coming.
and the trutrac may fit...I just dont think anyone's tried it yet.
but yeah, auto or manual makes a difference.
auto has the C200 (which there may or may not already be options available for depending on it nissan changed anything from previous versions)
manual has the M226 (D44 variant) which may or may not be identical to the titan rear end...if it is, everything for the titan should work, problem is, no one's tested that either. (cant see why nissan would have two different axles with the same designation but, then again, it is nissan so who knows)
'05 Storm Gray SE CC 4x4, 6M. PRG 2" f/r, OEM fogs/skids, 265/75r16 Yokohama Geolandar AT/S, stubbie antenna. (GONE)
'11 F150, Ingot Silver XLT Off-Road Supercrew.
Old 09-29-2007, 10:37 PM
GraviTitan's Avatar
Here's a link with all Nissan 1997 & up final drive ratios.
http://vibratesoftware.com/html_help...s.htm#Frontier
ALSO: Check out 4x4 COUNTRY. Free Online Game
http://www.4x4country.net/register.php?REF=14379
1999 Sierra SLT ECSB 2wd--Tow-Locking Diff, 5.3L, 3.42 gears, Dynomax S/T.
Exhaust Clip : http://www.youtube.com/watch?v=5Y-TYK3zONU
Click Here For Pics of My Truck and Videos of My Exhaust, Intake, and 0-60 Run!
Traded: 1999 Nissan Frontier XE K/C, KA24DE, 4.375 Rear Gear, Auto, 2WD, Black Emerald Green, 35% Front Tint, 245/60/15 Tires, 4WD Machined Finished Wheels, Weapon R Secret Weapon Intake, Dual Tip Rear Exit Exhaust!
Old 09-29-2007, 10:40 PM
It's an auto.
So I have a C200?
Is that the same as any other model/year?
Old 09-29-2007, 11:16 PM
GraviTitan's Avatar
Check the link I posted above. It lays it out for you.
Old 09-29-2007, 11:29 PM
Yup, thanks. Saw that right after I posted.
Now that's a bit confusing, so do I have an M226, or a C200?
2005-2007 Crew Cab A/T 4.0L- C200
2005-2007 A/T 4.0L- M226
The M226 must be the Nismo?
So I can take anything that, say a 2004 w/ a C200 can?
Old 09-29-2007, 11:41 PM
bake's Avatar
So I have the c200?
Old 09-30-2007, 12:03 AM
GraviTitan's Avatar
Yes, I believe the M226 is the Nismo. And unless there are other differences between the model years, I don't see why you couldn't use their components. But there is a limited slip version of it too. You may could swap it out or buy components to make yours limited slip. You could also probably swap it out for a year with a better rear gear for your driving style.
And yes, XE05 you have the C200 apparently.
CoastalD, are you 2wd or 4x4
