Gear Ratios? - Nissan Frontier Forum
post #1 of 20 (permalink) Old 11-09-2007, 01:15 AM Thread Starter
andrewcote's Avatar
Gear Ratios?
can someone explain gear ratios for me? i have been looking around the Forum and i cant find anyone that has talked about it.
See you in 2010
andrewcote is offline
post #2 of 20 (permalink) Old 11-09-2007, 01:24 AM
qborotali's Avatar
the higher the ratio the better accelration the lower the better fuel economy
2006 Nissan Frontier SE KC 4x4 6speed Manual...Black exterior Black Inteior...Black wheels, Volant CAI, Gibson Cat-Back, , wrp crank pulley, wrp grounding kit, traction leaf springs..Led Tailights, hid black halo headlights
qborotali is offline
post #3 of 20 (permalink) Old 11-09-2007, 03:43 AM
Inyourface1650's Avatar
Numerically anyway. Though technically a 3.69 is lower than a 3.13
Inyourface1650 is offline
post #4 of 20 (permalink) Old 11-09-2007, 04:00 AM
brutusvk's Avatar
Correct. Lots of fun trying to drive around town with 5.36 gears and a small block.
2005 Frontier NISMO CC - SUPERCHIPS tuned, Banks Exhaust w/ Flowmaster 50 series, Alpine 505 DVD HU, SIRIUS sat radio, Fosgate P3s 10" Subs in super crew box, Alpine 450M amp, JL 4300 amp, Alpine X series REF components & Alpine R series6 1/2 speakers, black pearl emblems, black billet shorty ant., AutoPage alarm, Billet Grille, AEM Brute Force CAI, Pathfinder switch covers, Titan Bilsteins, Shrock tank skid, Penski custom sliders, Cobra Roadtrip CB, Sylvania Silverstar wannabe HIDs & train horn.
brutusvk is offline
post #5 of 20 (permalink) Old 11-09-2007, 10:32 AM
jerryp58's Avatar
Quoted: 48 Post(s)
The gear ratio is the "number of teeth in the ring"/"number of teeth in the pinion". External to the differential, it's the number of driveshaft rotations to the number of wheel rotations; so you can get a rough estimate of your gear ratio by lifting the rear end of the truck, rotating a tire one full revolution and counting the number of times the driveshaft turns. That's why when you change tire diameter, you effectively change the gear ratio (e.g., when you put larger tires on, you need to turn the driveshaft more to get a single rotation of the tire which makes if feel like you have less power).
At least I think I've got all that right. Basically, it's what those guys said.
Jerry
2004 Frontier, King Cab, XE, 4-cyl, 5-spd, 4x1
K&N Drop-In Air Filter, Magnaflow SS CatBack Exhaust, Kumho Road Venture SAT 235/75-15, KYB Gas-Adjust Shocks, Pioneer AVH-P2400BT w/backup camera, Lund Tri-Fold Tonneau, Dupli-Color Bed Armor, Hellwig Rear 3/4" Anti-Sway Bar, eBay Fog Light Kit, Signaltone Dual Trumpet Air Horn, Rostra Cruise Control, Amsoil Transmission and Differential Oil, Mobil1 Crankcase Oil
jerryp58 is offline
post #6 of 20 (permalink) Old 11-09-2007, 10:47 AM
Phil'sFrontier's Avatar
I would suggest searching Wikipedia. It's better for stuff like this than Club Frontier....sorry guys...
2006 SE KC 4x4 auto -- Shrock BFG AT OEM fogs
Phil'sFrontier is offline
post #7 of 20 (permalink) Old 11-09-2007, 11:37 AM
qborotali's Avatar
my friend just put 4.10 gears in his 07 gt mustang i tihnk from a stock 3.4 somthing i dunno sometihn liek that
post #8 of 20 (permalink) Old 11-09-2007, 01:00 PM Thread Starter
andrewcote's Avatar
ok thanks alot. so i would want a higher gear ratio for offroading? what would be a good Ratio? its not for my Frontier, im learing up because im about to buy a Sami and i want to learn about this stuff
See you in 2010
post #9 of 20 (permalink) Old 11-09-2007, 01:17 PM
hehe, ok. So numerically higher, the lower the gear ratio. jerry kinda explained it backwards from how I think of it. If you have 4.11 gears, you will turn the driveshaft 4.11 times before you turn the tire. So if you are in 5th gear (2nd Gen 6 speed) which is 1:1 you get 4.11 turns of the engine for one turn of the Tires.
Now obviously the more turns of the engine to the turn of the Wheels means more torque (this is how your transmission works). Offroad (like the sammy) it also effects your crawl speed. My truck, which is a manual, has the lowest rear gear of frontiers 3.69, so I can crawl around very slowly with the clutch fully engaged.
In a sammy, especially with the stock 55HP, its very important to gear em right, otherwise you will not be able to go anywhere for lack of power.
Tires affect gearing in the following ways: lets imagine we are in our scenario above. You in 5th gear, which is 1:1, and you have 4.11's. So 4.11 turns of the engine for every turn of the tire. So when you mess with tire size, you are effectively messing with your final drive ratio. Now, with 31inch tires you travel 31*pi or 91 inches. With a 33 inch tire you travel 103inches for every turn. So see how bigger tires mess with your speedometer? Your spedo thinks your going a foot less every tire rotation then you actually are. You have also effectively made your gearing taller, since every turn of the tire takes you farther. (so your truck will have less power) If you make your rear gears Shorter (or numerically higher, but actually lower) to say, like a 4.33.....You once again be going about the RPM at about the speed you were, effectively correcting for the bigger tires. This is why you see people talking about gearing for 35" tires and such. You lose so much power (beacuse you go so much farther for each rotation of the wheel) its necessary to re-gear the drivetrain to get it back.
post #10 of 20 (permalink) Old 11-09-2007, 01:25 PM
Mainerunr's Avatar
nice edit, between reading from the start and hitting quote you fixed what I was gonna....
4.10 gears would be nice for wheeling but would kill mileage on road since the engine would constantly be taching higher (well, highway anyway, the other speeds you correct by being in a different gear). I suspect thats one reason why I get the same mileage in this truck with 33's as I got in my '97 D21 with 31's. that pig had 4.56's and tached 3k on the highway.
'05 Storm Gray SE CC 4x4, 6M. PRG 2" f/r, OEM fogs/skids, 265/75r16 Yokohama Geolandar AT/S, stubbie antenna. (GONE)
'11 F150, Ingot Silver XLT Off-Road Supercrew 275/65/18 Toyo AT2's
Mainerunr is offline
  Nissan Frontier Forum > Nissan Frontier Forums > OffRoad / 4x4
