I've got the PRG 3" suspension lift with radflos, PRG UCAs and rear AAL. I'm considering a 2" body lift only to get some clearance for my tires which rub on the fender even after trimming.
The lift says extended brakes lines are not required but I'm thinking with my existing lift I may need to.
1. I'm running stock brake lines, should I upgrade to extended brakes lines with this?
2. Does the Automotive Customizers (4x4parts.com) 2" kit work with the plastic front bumper. I have replaced mine yet.
3. I've got rock sliders welded to the frame how stupid will they look if I through on a 2" BL but they stay in the same location?
Thanks
Thanks
