Nissan Frontier Turn Signal / Tail Light LEDs! Plug & Play! See Bulb Model Options!
Nissan Frontier LED Tail Light LEDs
From the factory, tail light bulbs are powered by standard incandescent lights that light up white in color, and cast light through your red or amber tail light lens. This results in a washed-out color.
Newer luxury vehicles are using LEDs for turn signals, because LEDs offer a crisp, instant on/off function, increased brightness, and true, vibrant color. By replacing the bulbs in your Frontier, you can achieve this modern look!
Brightness
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb compared to factory:
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Bulb Design:
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Included in your order is TWO BULBS.
Front Turn Signal LEDs for 1998-2000 Nissan Frontier (pair)
Front Turn Signal LEDs for 2001-2004 Nissan Frontier (pair)
Front Turn Signal LEDs for 2009-2012 Nissan Frontier (pair)
Rear Turn Signal LEDs for 1998-2004 Nissan Frontier (pair)
Rear Turn Signal LEDs for 2005-2012 Nissan Frontier (pair)
Tail Light LEDs for 1998-2004 Nissan Frontier (pair)
(Xterra shown as comparison)
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
If you have any questions, please don't hesitate to post, PM, emailcontact@diodedynamics.com or call: (314) 205-3033
Thanks for looking!
Nick C.
Diode Dynamics
Brightness
Bulb Design:
Thanks for looking!
Nick C.
Diode Dynamics
