Nissan Frontier Reverse/Backup LED Bulbs! Plug & Play Install!
35K views 65 replies 16 participants last post by  Diode Dynamics
#1 · (Edited)
Nissan Frontier Reverse/Backup Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your Frontier's reverse light or backup light bulb (3156 / 921). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two LED bulbs for perfect fitment in your Frontier model year selection.
Bulb Design
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
Bulb Fitment:
2005+ Frontier Model Years (921) use a quality inject-molded 921 terminal, with a sturdy base connector and proper pin alignment, designed for exact replacement of your factory 921 bulb. You will not need resistors for backup lights. Just replace the factory bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP36: (210 lumens) Slightly higher brightness than OEM bulbs.
XP50: (410 lumens) Much brighter than OEM bulbs.
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
Thank you!
Nick C.
Diode Dynamics
#2 ·
Bright Lights, Big City
Review by Bruce,
"The LED back up lights I ordered arrived very quickly. These rascals are expensive, but I am sold on LED technology, and they are almost like having landing lights on the back of my Frontier when reversing. I will likely be purchasing other LED lights from Diode Dynamics. This company is a pleasure to deal with, and their products are top notch." (Posted on 11/10/15)
#4 ·
What brightness level (bulb model) did you go with?
#11 ·
subscribed
Reactions: Diode Dynamics
#14 ·
Of course we do! We are big fans of the Frontier at Diode Dynamics. (Our operations manager has owned two and is a member himself)
You don't have to disconnect the battery, but it is an excellent precaution. Make sure the socket isn't on when you are installing the LED replacements.
So Diode, are the HP5 (92 lumens) bulbs in stock now?
As well on your website there is no option for the 3rd brake light.... do you have them in the HP5?
We do have HP5s in stock and ready to ship. The third brake should also be a 194/921 so HP5 in red would be a great choice
Thank you!
Nick C.
#13 · (Edited)
#15 ·
Just bought my reverse, 3rd brake, and license lights HP5!!! Can't wait to install them! The guys on the phone were great! :)
#17 ·
I installed your HP36 reverse and cargo bulbs last week. Love em! I'll be ordering interior lights and fogs in the future. I hope to see a 9007 headlight bulb in the future. When I find a company I like, I try to keep my business in one place to show my support. Good job.
#32 ·
I purchased the XP50 410 lumens, Backup and cargo lights the other day. I did not know about the free shipping offered to forums members at the time :(. I also purchased some interior LED lights. I'll post what I think about them after using them for a week or so. I hope they are not too bright!
