Nissan Frontier Reverse/Backup LED Bulbs! Plug & Play Install! - Nissan Frontier Forum
 4Likes
post #1 of 55 (permalink) Old 10-27-2015, 02:23 PM Thread Starter
Site Sponsor
Diode Dynamics's Avatar
Quoted: 11 Post(s)
Arrow Nissan Frontier Reverse/Backup LED Bulbs! Plug & Play Install!
Nissan Frontier Reverse/Backup Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your Frontier's reverse light or backup light bulb (3156 / 921). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two LED bulbs for perfect fitment in your Frontier model year selection.
Bulb Design
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
Bulb Fitment:
2005+ Frontier Model Years (921) use a quality inject-molded 921 terminal, with a sturdy base connector and proper pin alignment, designed for exact replacement of your factory 921 bulb. You will not need resistors for backup lights. Just replace the factory bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP36: (210 lumens) Slightly higher brightness than OEM bulbs.
XP50: (410 lumens) Much brighter than OEM bulbs.
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
Thank you!
Nick C.
Diode Dynamics
Diode Dynamics is offline
post #2 of 55 (permalink) Old 12-18-2015, 04:24 PM Thread Starter
Site Sponsor
Quoted: 11 Post(s)
Bright Lights, Big City
Review by Bruce,
"The LED back up lights I ordered arrived very quickly. These rascals are expensive, but I am sold on LED technology, and they are almost like having landing lights on the back of my Frontier when reversing. I will likely be purchasing other LED lights from Diode Dynamics. This company is a pleasure to deal with, and their products are top notch." (Posted on 11/10/15)
post #3 of 55 (permalink) Old 02-17-2016, 09:19 PM
SKOLJACK's Avatar
Quoted: 3 Post(s)
I'm really happy with my Diode Dynamics LED licence plate, reverse, & cab lights.
CAUTION: This space reserved for nonsense!!!
SKOLJACK is offline
post #4 of 55 (permalink) Old 02-17-2016, 09:42 PM
KAB
KAB's Avatar
Quoted: 35 Post(s)
What brightness level (bulb model) did you go with?
2009 CC LB SE 4x4 Auto. Rad Silver * Suspension: TJM front ext. travel coil overs (med. duty springs) w/ 1" top plate spacer, SPC upper control arms, Old Man Emu Dakar med. duty leaf springs w/ TJM rear ext. travel shocks * Tires: Toyo Open Country AT2 265/75/16 * Wheels: Level 8 Bully Pro * A/V & Nav: Pioneer Avic 8100, Alpine pdr-v75, Alpine R components, JL Audio 10 tw-3, Alpine HCE-C125 rear view camera mounted under tailgate handle * Morimoto XB led fog lights / Beck Arnley (Titan) light stalk with fog light switch
KAB is offline
post #5 of 55 (permalink) Old 02-17-2016, 09:56 PM
SKOLJACK's Avatar
Quoted: 3 Post(s)
HP5 (92 lumens).
SKOLJACK is offline
The Following User Says Thank You to SKOLJACK For This Useful Post:
KAB (02-17-2016)
post #6 of 55 (permalink) Old 02-18-2016, 09:36 AM Thread Starter
Site Sponsor
Quoted: 11 Post(s)
It looks fantastic @SKOLJACK !
Thank you for posting pictures with everything installed! We are glad you like the upgrade!
Nick C.
post #7 of 55 (permalink) Old 03-17-2016, 09:53 AM
BravoBravo's Avatar
Quoted: 6 Post(s)
Here is a pic of my back-up lights in action.
Bruce Brown
London, Ontario
Canada
2011 Nissan Frontier
BravoBravo is online now
post #8 of 55 (permalink) Old 03-17-2016, 10:28 AM Thread Starter
Site Sponsor
Quoted: 11 Post(s)
Looking good!!!
Nick C.
post #9 of 55 (permalink) Old 03-17-2016, 10:37 AM
BravoBravo's Avatar
Quoted: 6 Post(s)
Thanks, Nick! Great products! - Bruce
Bruce Brown
London, Ontario
Canada
post #10 of 55 (permalink) Old 03-22-2016, 03:14 PM Thread Starter
Site Sponsor
Quoted: 11 Post(s)
Thank you Bruce!
Nick C.
  Nissan Frontier Forum > Vendors > Diode Dynamics
