Frontier Footwell LED Kit! RGBW Multicolor & Single color kits! Control w/Smartphone!
15K views 53 replies 5 participants last post by  Diode Dynamics
#1 · (Edited)
Looking to add a little color to your Frontier's interior? Diode Dynamics' RGBW Multicolor Footwell LED kits are the way to do it! By adding Diode Dynamics' LED strips under your dash, you can add RGBW color-changing ability to your Nissan Frontier's footwell area.
This kit is not just RGB, it is RGBW! That means there is an extra integrated LED chip that is specifically white in color, right next to the standard red, green, and blue LEDs. By using an RGBW controller, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals.
Our Bluetooth Controller will allow you to choose any color under the sun, including True White, directly from your phone! Our mobile app includes a wide variety of features including strobe and fade effects, preset colors, Camera Match, Music Sync, and much more. Our controller will also allow you to adjust the brightness of the LED strips. Any time you power up your strips, they will default to the last color that was previously selected.
These LED strips in this kit are highly flexible and waterproof. They feature high-density LEDs chips for brighter output and barrel-style M8 connectors for a secure connection.
Included in the 2-Piece Kit:
  • Two (2) 50cm RGBW SMD30 Strips
  • One (1) wiring harness (4-foot)
  • Two (2) quick splices
  • One (1) red LED toggle switch
  • One (1) DC-to-DT adapter
  • Four (4) zip-ties
  • One (1) 3M outdoor adhesive pad
Included in the 4-Piece Kit:
  • Four (4) 50cm RGBW SMD30 Strips
  • Eight (8) zip-ties
  • Two (2) 3M outdoor adhesive pads
  • Two (2) RGBW M8 extension wires
Footwell Kit Installation Video
The 2-piece kit includes everything you need to install LED strips in the front footwell area on both the driver and passenger sides of your vehicle. The 4-piece kit includes everything you need to install LED strips in the front and rear footwell areas on both the driver and passenger sides of your vehicle. This kit is very universal in nature and can be tapped into any 12V power source that you would like when installing.
Any questions email us at contact@diodedynamics.com or call: (314) 205-3033
PM us for the free-shipping code (U.S. forum members only)
Thanks!
Collin O.
#5 ·
My question, and I suppose I would have to call, is how many of these LED kits can connect off of one RGB controller? I would prefer to have the one under each footwell, but then another under the front seat lip to provide more uniform lighting, and possibly under the rear of the seats as well to light up the rear seating area. That I assume would include 3 LED kits but how easy is it to control them all from one single controller?
I'm just not up to date on all the new fangled stuff. I'm used to old school where I wire up as many lights or amps or speakers as I feel like it and put them on a single toggle switch. Very old school. Now it's all wifi and bluetooth and whatnot.
#6 ·
You can power quite a few strips with just one controller. You can add as many 2-way splitters as needed depending on how many outputs are desired.
The standard kit with rear footwell option will have plenty of output for your front and rear footwell locations.
Feel free to give us a call if you have any questions: (314) 205-3033
Thank you!
Nick C.
