  #21 (permalink)
Old 02-11-2008, 02:03 AM
duckhunter71's Avatar
Gilette Mach 3 Turbo razor with Edge gel. Shaving cream just smells bad..
2008 Chevrolet Silverado Z71 LT
  #22 (permalink)
Old 02-11-2008, 02:05 AM
nismo4x4055's Avatar
Send a message via AIM to nismo4x4055 Send a message via Yahoo to nismo4x4055
i use the mach 3 razor, and barbasol beard buster shaving creame... been using that since i started shaving.
current mods- 265/75/16s maxxis buckshot m/ts, k&n air filter, bug deflector, cobra 19ultra lll cb radio, truck spec antenna
future mods- a/c 2.5 inch lift, 3 inch body lift, custom dual exhaust, westin bull bar, air intake.
  #23 (permalink)
Old 02-11-2008, 08:18 AM
I use the Gillette Sensor 3 with gel. Tend to break out a lot though when i shave.
  #24 (permalink)
Old 02-11-2008, 11:20 PM
roc_my_tims's Avatar
i make life easyh, my barber shaves my face every 2 weeks. during my normal haircut
07 white se CC
changed interior lights to blue bulbs,changed antenna to 12 inch rubber, bakflip cover
  #25 (permalink)
Old 02-12-2008, 12:58 AM
06_footy's Avatar
I use Gillete regular & publix 3 blade razor's. It's a store here in the south, where i work as a cashier. It's just really easy.
myspace.com/unawareconception
2006 crewcab SE 2wd
  #26 (permalink)
Old 02-12-2008, 01:04 AM
fleaofsc's Avatar
Send a message via AIM to fleaofsc Send a message via MSN to fleaofsc Send a message via Yahoo to fleaofsc Send a message via Skype™ to fleaofsc
I use Crazy Squirrel
  #27 (permalink)
Old 02-12-2008, 01:49 AM
06_footy's Avatar
ur a flippin loser
2006 crewcab SE 2wd
  #28 (permalink)
Old 02-12-2008, 03:06 AM
BoyInBlue2658's Avatar
u have to try different brands out. what works for us may not work for you due to different skin types
R.I.P LAPD Ofcr. Randy Simmons "R 41 david" EOW 2/7/08
  #29 (permalink)
Old 02-12-2008, 08:35 AM
Avplayer's Avatar
Send a message via AIM to Avplayer
i use Gillete Fusion and don't use any gel or anything...
  #30 (permalink)
Old 02-12-2008, 09:36 AM
KellyJoe's Avatar
Originally Posted by 07Frontier View Post
I use a double edge Merkur razor
I use the same going from Mach III. Awesome razors.
Another tip I read off another site that really works well. Dry whatever blade you use with a hairdryer or give it a dunk in alcohol before storing it for the day. Something to do with the moisture and corrosion on a microscopic level at the edge of the blade. Blades last a lot longer. I have to shave every day and had a Mach III blade last for three months this way. No BS. Try it. It'll save you money.
