The incorrect theories that abound in this thread have three types of errors. First is reading comprehension. The statement: "Will the plane take off" implies that the pilot has engaged the engines at take-off thrust. No half throttle, no partial throttle; full take-off power. The second error is basic physics. The propulsion system on an airplane is by momentum balance. The momentum of high velocity gases exiting the engines is counterbalance by forward momentum. The observed motion of a balloon caused by a sudden release of air is but one example of this principle. You can put wheels on the balloon and put it on a moving conveyor. But the balloon acts on the expulsion of air and will ignore the wheels. The third error is assuming the conveyor can move the plane. There is only a frictional coupling to work with. This is poor at best. We can compare this with an open differential. In a situation where one wheel has no traction, how much torque is delivered to the other wheel? Not much. The internal friction in the open diff is not sufficient to transmit torque. This is why we have lockers. If the pilot applies full take-off power to the plane, it will take off. The conveyor can go backwards, forwards, same speed, half speed, twice speed, or any speed, and the plane will take off. There is nothing the conveyor can do to prevent take off because the plane is driven by the forward momentum created by the engines.
06 Nismo 6M 4X4 Blue |
Storm Gray '06 Frontier SE Crewcab 4.0L 4x2 No mods yet.
BTW: the conveyor most certainly CAN move the plane. Turn the conveyor without having the plane on, and it will move backwords. However the maximum potential for any treadmill to affect the plane is far exceeeded by an engine. |
We all agree that the plane could take off if the treadmill speed equals -plane speed, the details of the real wording have been hashed out. Wheel speed is only relevant here if you're using wheel speed to set the speed fo the treadmill because that will set the speed of the plane relative to air. The plane must still reach liftoff speed to get into the air and, if wheelspeed = treadmill speed, the plane is not moving relative to the air...plane velocity relative to air is the only thing that matters for takeoff.
I'm done with this one. Group A not understanding the subtle difference in details being discussed by group B is not getting anywhere.
Yo, someone should try this with a remote control plane and a treadmill, tape it and put the video on you tube. Case closed
