well heres an easy physics answer, dont hurt your brain thinking too hard...It would be similar to have a plane in "neutral" at full throttle. that is assuming the treadmill is going fast enough to keep from any foward movement in the wheels to transfer into foward movement of the actual plane, (potential and kenetic energy). SIMPLE
Your still going to have to travel through air. Basically the treadmill is just a slingshot to build up the neccessary speed, just like a catapult on an aircraft carrier. You arn't magically going to be flying when the power to the treadmill is shut off.
![]() ___________________________________________ '04 Super Black CC K&N intake, Nismo exhaust, Painted Calipers, NGK Iridium IX sparkplugs w/ wires, Nismo Floormats, Street Scene Grill, Sirius, Club Frontier Sticker, PowerSlot Slotted Rotors |
Oh.... I didn't realize that the treadmill would be shut off. That makes this a little more debatable.
it can be on or off. Regardless, the plane won't fly unless it travels any sort of distance.
treadmill will spin the tires, big deal, planes dont propel with their tires so, the props or jet engine will push against the air like they always do, the treadmill will add a little resistance at the 'freely spinning*' wheels and the plane will take off.
* - freely spinning as in they are not driven but yes, there will be a little friction, no biggie. oh, and of course there's no wind when you run on a treadmill, your propulsion system is the very thing in contact with the treadmill, not so with an airplane. the plane pushes against air, not the ground. do we really have to relive this again?
So what is even keeping the plane on the treadmill... I would say that it would just roll forward past the treadmill as if it wern't there. The treadmill would just make it spin its tires faster for a second.
what do you guys think the treadmill is doing to the plane to keep it from moving forward? the brakes on the wheels would be off so they can spin however fast the treadmill moves and it doesnt matter since that's not the method of propulsion for the plane. why is there even a question here? the plane will move forward.
'05 Storm Gray SE CC 4x4, 6M. PRG 2" f/r, OEM fogs/skids, 285/75r16 TRXus M/T's, stubbie antenna. Last edited by Mainerunr : 12-12-2007 at 07:16 PM. |
This problem would not be worthy of a "Physics for non-physics majors" type of class. No thinking involved with this one. I wonder how the demonstration will be staged?
06 Nismo 6M 4X4 Blue |
I think it is one of those questions that seems simple but can be over-analyzed.
USE TO HAVE: 05 white Nissan Frontier SE crew cab full billet grill pinstriping and rear lettering removed |
